Superior loader on a 9n?
   / Superior loader on a 9n? #1
gears351
Ford 9N
Anyone out there have any experience with a FEL on a 9N? I'm looking at a parts tractor that's got one (Superior is the brand, front driven hyd pump, 4 cyls on the frame work - so it's not a trip bucket) and I was considering putting it on mine.... I use my 9 with a slip scoop digging in the woods/back yard with the kids, leveling a wooded lot 3 or 4 bucketfuls a day before supper. Will this FEL help me or should I stick with the slip?
Thanks
   / Superior loader on a 9n? #2
the scoop can dig.. the loader won't.. it scoops stockpiled material.. or is a mobile crane.
makes steering hard.
on the other hand.. I'd use a loader before a wheelbarrow ANY day.
I always used scoops till I got a loader.. I like my loaders.. if I need to dig.. I get the box blade or scoop out.. :)
soundguy
   / Superior loader on a 9n? #3
The n's are great tractors, but definitely not good on a loader. The lack of power steering makes steering tough with a load, the front axles are not designed for the extra weight forward, lack of 4wd makes getting a full bucket tough on other than loose material, and all that extra weight and bulk takes away much of the advantages of these compact tractors. I would stick with the rear scoop. A 9n is better than an 8n on one of those because it has a lower reverse gear. You can always sell that loader to a horse-person, many of whom own n's and use them for loading manure, which is about the only task a loader on an n does ok at.
Thanks guys, will a box scraper "dig" better than the scoop? I'm using mine in reverse in the woods and I'm finding the root systems cause it to bounce up & ride along the surface (thinking of adding a weight box to the top of it) I contemplated adding teeth (I saw someone made a detachable tooth setup for a FEL that would probably work well). I'm not digging to make a hole, I just want to pull dirt from the high corner of my lot and level some of the many dips & holes where trees used to be.
Reading what I just wrote I realize the scraper can't move dirt over the several hundred feet I need unless I drag it there..... But would it make piles I could carry in the loader?
So, is it worth it for me to put said loader on the N?
   / Superior loader on a 9n? #5
Try the scoop in the forward position. Usually they dig a lot better that way and you wont risk bending your lower links. Adjust the top link in a bit so that you get a decent angle on the front edge as it contacts the ground. I am guessing a pond scoop in the forward position would be about the most efficient tool available to use on an n for your task of moving dirt from high spots to low spots. Its kind of like a scaled down version of them big "Pans" they use for big jobs. It lets you dig, transport and dump, while a box scraper, front loader, or rear blade may do one or two of them tasks but not all three as effectively as a pond scoop.
thanks wolc that's what I wanted to hear.
   / Superior loader on a 9n? #7
Hey all! I've got a gravity down unit on my 1951 TO20 Harry Ferguson. I think this is close to a 9N. It has hydro dump bucket and does a fair job digging; however, the bucket is not wide enough to offset the earth for the front wheels. The teeth make all the difference. My tractor is hard to steer with a full bucket and the loader connects with 3 bolts up front and 4 in the rear. I have ballasted tires and a 3pt weight to counterbalance. I do not like it as compared to my modern Branson, but I do not think I would ever had bought the new tractor if I had the Fergy first.
   / Superior loader on a 9n? #8
I'm pretty sure the rest of the thread is refering to a 3pt scoop, and not a fel.
soundguy
   / Superior loader on a 9n? #9
soundguy
Hey Soundguy, isn't he asking about an FEL?
Yeah guys, I was primarily asking about the FEL - that deal fell through though.... Thanks for all the feedback. The wife is pleased I won't be bringing a parts tractor home!
And your tips with my slip scoop have been great, thanks!
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
