Super UDT2 in a Kioti
/ Super UDT2 in a Kioti #1
iflywhatevr
Hadley, MA
Kioti CK3510 SE
Any Kioti owners running Kubota Super UDT2 in their CK Series HST’s? Getting ready to change mine my local dealer services with Mahindra fluid they say is a good quality fluid (they are a Kioti and Mahindra dealer). But I’m not really sold on the Mahindra fluid which is not specified in the manual either for Kioti as far as I know. From what have read the UDT2 does very well in the Kubota HST tractors to quiet down the HST whine.
/ Super UDT2 in a Kioti #2
For what it's worth, I've about decided to use SUDT2 in my Branson. Expensive though. Local Kubota dealer wants slightly more than $100 for 5 gallons. Anyone got a better deal on it?
It’s 103.57 here for 5 gal. Can’t find it anywhere cheaper other than online which ends up being more expensive with shipping.
/ Super UDT2 in a Kioti #4
Kioti isn't going to specify another manufacturers proprietary brand. Kioti does make there own brand of HST fluid.
I have a couple of 5 gallon containers of it in case I ever change the entire 11 gallons at once. So far no need, I only change the filters, by recommendation of my dealer, in over 1,500 hours on my two Kioti's since 2009.
I find the change the entire HST fluid thing over rated and largely unnecessary, so long as one does not allow contaminants into the system, there should be no reason to have to change it out. The filters are micronic, and the system is sealed. As long as one is using their own attachments, keeps their QA, QDs capped and plugged and stores the machine where rain/snow or other water cannot enter the hydraulics, one should be able to maintain system integrity without a lot of effort. If fluid becomes contaminated or milky- a sign of water contamination, then change it out. All I've ever done over the last 9 years is top off the factory fluid with UTF and wet brake additives, from TSC - as long as it meets or exceeds the specs. that the tractor Mfg. calls for.
/ Super UDT2 in a Kioti #5
KOUA mentioned recently that he has used SUDT2 in his Kioti tractor for a few years and it is all he will use/recommend. I'll try to find the thread.
Not the thread I remember seeing, but here is one: SUDT2 in Kioti
/ Super UDT2 in a Kioti #6
I am very frustrated with the cold weather behavior of my DK40 SE HST. I ran some viscosity tests comparing; what Kioti shipped in my tractor, the top of the line fluid from TSC and the Kubota SUDT2. The TSC fluid was the thickest, the SUDT2 was the thinnest and the Kioti fluid was between them, but closer to the TSC fluid than the SUDT2. I am going to cough up the $$$ before fall and replace my HST fluid with the SUDT2. My dealer told me he doesn't believe in spending the money for synthetic fluids, he said I could use any fluid that met Kioti's specs. With one exception, don't use any hydraulic fluid from TSC! He was very adamant about that, he said the only HST issues he has seen has been when somebody had used the TSC fluid.
/ Super UDT2 in a Kioti #7
I am using SUDT2 in my DK35se. I immediately noticed less noise from the power steering in cold weather. And better cold weather performance overall. I was using the Kioti reccomended Mobilefluid 424.
/ Super UDT2 in a Kioti #8
Doing my 50 hr service within next couple weeks and will change to SUDT-2 like i did in last machine. I'd like to quantify somehow if better/worse/same going to SUDT-2 vs whatever is in there now (Chevron something I think is what my dealer said he uses). I notice no poor performance or HST whine now.
So how can I measure? I was thinking of setting camera on a tripod, driving past at engine idle, full HST pedal. Then repeating at high engine RPM. Then with empty bucket, measure time to go from ground fully curled, raise to full height, uncurl, recurl, lower. Do both those before and after the fluid swap to see if there is any difference I can observe.
What else could I do to "test" if one actually performed better than the other? Several months away for any cold weather behavior comparisons and I haven't had this machine with original fluid in cold weather. Other things that might show a difference? Pulling a hill in H, lifting a test load that maxes loader (something I can get off ground, but go into relief a couple feet up). That's all I can think of. But if there is something I can do that's easily repeatable and would demonstrate if there is any real world performance difference in one fluid vs the other, give me some ideas and I'll do it - assuming it is within my technical proficiency (low) and tools on hand (basic).
When I did my LS, I didn't notice anything much from OEM fluid to SUDT-2 swap. Seemed to drive and lift the same. I did notice less HST whine. Not night/day difference, but enough I could easily tell it was less after swapping to SUDT-2.
/ Super UDT2 in a Kioti #9
These test are very subjective and hard to prove. I didn't have much whine to begin with. But the power steering made some noise when it was cold until the fluid got warmed up. The SUDT2 fixed that. So better cold weather performance. I think that all the premium fluids are going to be pretty close. Some will notice reduced performance with the "bargain bin" fluids. But proving how one premium fluid performs against another premium fluid is gonna be hard.
/ Super UDT2 in a Kioti #10
I've used the factory supplied HST fluid in both my 2008 DK-35SE/HST, and my 2010 DK-40 SE/HST for a combined 1,500+ hours, topping off the 2010 with either TSC HST fluid OR Kioti's own HST fluid- no problems whatsoever in either tractor/power steering, cold or hot weather, or any usage parameters.
YMMV, but I think it also has to do with factors like storage. (My tractor(s) have been kept in a temp controlled, never below 50 degrees F barn bay, for comparison purposes).
/ Super UDT2 in a Kioti #11
JD20C trans/hydro fluid is the same spec as Mobilfluid 424 and available at every Fleet store and NAPA in the nation.
/ Super UDT2 in a Kioti #12
I noticed after replacing my fluid with SUDT2 that the loader responds MUCH faster after startup when cold, HST is quieter as well. Overall just seems to run better.
/ Super UDT2 in a Kioti #13
The SUDT2 has very good specs and in fact has the best viscosity index of any UTF I have seen. I use Klondike full syn in my Kioti because the price is reasonable and it has better low pour point specs than the SUDT2. The SUDT2 is a low viscosity UTF, lower than most I’ve seen, which would make the hydraulics flow faster, however, I think the Klondike would out-perform it in really cold weather; ie -35C.
/ Super UDT2 in a Kioti #14
marchanna,
Where did you buy the Klondike oil? I see there is a distribution warehouse in Moncton but they don't list any resellers on their website?
My DK40 should have a hydro oil change before winter arrives.
Jason
Did my 50 hour on my CK3510SE today. Bought two 5 gallon buckets of the SUDT2 for $103 each. Took it for a spin afterwards so far so good. As far as quieter hard to say since it was 100 degrees out and tractor was still warm from before the oil change.
/ Super UDT2 in a Kioti #16
Just changed the fluid in the CK27 at 650 hrs. I went with Shell Spirax S4 TXM......Kioti approved. Got 2/ 5 gal pails at $45 a pail. Tractor runs fine, can't see spending $100 a pail when there is equal fluids far less. I got mine at the local Shell distributor which you will find is much cheaper.
/ Super UDT2 in a Kioti #17
Look - there has got to be a point where I say - - STOP!!! When the hydraulic fluid I put in my tractor costs more than the whiskey I drink.....................
/ Super UDT2 in a Kioti #18
Perhaps you should look into a little higher grade of whiskey?:D
/ Super UDT2 in a Kioti #19
Super UDT2 and Shell spirax s4 thx are two totally different fluids. UDT2 has a JD20D spec and the Spirax has a JD20C spec. I had a JD20C spec fluid in my CK35 and it was to high a viscosity for the PA winters. I would have to warm up hydro fluid for 25 min before I could drive the tractor. I could lift the loader, but it would be into relief until the fluid was warm. With the Super UDT2, I can now start the tractor and start working.
Any fluid rated for hydraulics and wet brakes should be fine, just choose the temp range you will be operating in.
/ Super UDT2 in a Kioti #20
I didn't realize water could get into the hydraulics just by the tractor getting rained on. I don't have a covered area to park yet, just a tarp. Would like more information on how this could happen. Thanks!
