Super UDT?
   / Super UDT? #1
sparkkky
Oklahoma
Kubota B21
Priced the Super UDT at $40.00 a jug, is there a cheaper place to get it, or is any brand as good plus cheaper?
NH's fluid is $18.00 a jug.
   / Super UDT? #2
what ia a "jug"? It looks to me to be like the 2.5 gallon jug?
   / Super UDT? #3
sparkkky,
What are you going to put it in? People that have used something other than the Super UDT in the Kubota RTV, have found performance problems. When they switched back, the issues went away.
Brian
   / Super UDT? #5
Anyother fluid that passed Kubota UDT is 100% fine.
   / Super UDT? #6
I have read a couple of posts where folks used something else and had to change it back out with the Super UDT because the other didn't work right.
Personally, with my $12K tractor I am going to use the Kubota filters and fluids. Why take a chance just to save $20?
Bill Tolle
   / Super UDT? #7
Try pricing it by the 5 gallon bucket. The dealers near me Ann Arbor/Detroit charge between $63 and $75 for the 5 gallons.
The Super UDT is a synthetic oil. It will be more slippery at lower temperatures when compared to regular Kubota UDT oil. Kubota machines have been known to be slightly fussy about the hydraulic and gear oil used in them. The Super UDT works real well. I use it and recommed following the recommendations stated in the owners manual.
Just like people; all machines are not designed or created equal.
   / Super UDT? #8
I had followed the advice of my former "dealer" and used regular fluid - never again.
The Super UDT gives me more power both to the ground and to the FEL.
What is the dealer qualification requirement anyhow - a handful of cash and a substantial intial order?
These guys were such idiots, I can't tell what the qualifications are.
Examples of their bad advice:
"Don't baby this thing, run it at full speed for everything"
(contrary to the manual's advice on break in procedures)
"We don't even carry Super UDT, just use regular hydro fluid"
(also contrary to the manual specs, and even a warranty voiding activity)
"Teeth for your FEL? Never heard of that"
(best darn money I've spent was on a toothbar)
When they delivered my tractor, they started it up cold, immediately revved it up to full speed, and backed it off the trailer. (I always let it warm up before doing anything)
They also mounted the MMM, and didn't both to connect the drive shaft for it. (minor but still stupid).
The tiller came in about a month later. They delivered it, and neglected to cut the PTO shaft, so they had to come out again.
Just a bunch of stupid stuff that I would not expect from a Kubota dealer.
I now have found a very competent dealer, and am very satisfied with their work, and work ethic. Thankfully.
   / Super UDT? #9
When it was time to change the fluid in my new B21 it was the same story - dealer(s) didn’t carry Super UDT but we use this stuff (see attachment).
If Super UDT was that important is seems like Kubota would make the dealers recommend it and/or have it in stock. Most other manufacturers always have the dealers stock and push the their products.
Anyway, after 300 hours using the dealer “stuff” my B21 appears to be working just fine. Other than some subjective statements I haven’t heard of anyone complaining about non-Kubota fluids causing any real problems.
Oh yeah, $29.50/5-gal.
   / Super UDT? #10
I am sure You are aware of the following that is supposed to be a substitute for Super UDT.
Chevron Synthetic All-Weather THF
Chevron All-Weather THF is a truly unique, high quality, multifunctional fluid, specially formulated for use in transmissions, final drives, wet brakes, and hydraulic systems of tractors and other equipment employing a common fluid reservoir.
Chevron All-Weather THF is specially designed for unsurpassed operation in all types of weather - both severe winter cold and extreme summer heat. In fact, Chevron All-Weather THF meets the requirements of both John Deere J20C and J20D specifications. This, combined with excellent oxidation stability, eliminates the need for seasonal oil changes.
Its distinctive orange color provides for easy product identification and leak detection.
· Chevron Synthetic All-Weather THF is recommended for use
· as a multifunctional and multiseasonal fluid in all types of tractors and construction equipment.
· in any application which calls for the following OEM lubricant specifications:
John Deere - J20C, J20D
AGCO - improved power fluid 821XL
Ford New Holland - ESN-M2C134-D, FNHA-2-C-201, FNHA-2-C-200
Massey Ferguson - M1135, M1141, M1127, M1129A
White Farm Equipment - Q-1826
Case - JIC-143, JIC-145, MS 1206, MS 1207
Oliver - Type 55
Minneapolis-Moline Fluids
Caterpillar TO-2
Renk - Bus Automatic Transmission Fluid
Allison C4
Kubota Super UDT, UDT
International Harvester B6
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
Unused Delta Crash...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
