super udt hydraulic fluid
   / super udt hydraulic fluid #1
Anonymous Poster
Epic Contributor
can anyone tell me the iso grade of super udt? i'm looking for a comparable product. any help would be appriciated.
   / super udt hydraulic fluid #2
You must be rich. The UDT is a lot cheaper and the only difference is cold weather attributes.
Daryl
Forage Services, L.P.
i want to know the iso grade so i can use a different brand if possible- super udt is way to expensive because kubota brands it in their name, thus charging a premium- do you know the iso grade on udt or super udt??? or a similar product that will work in my bx series?
btw- if you ask most democrates, i am rich- too bad i just dont see it!!!! lol
   / super udt hydraulic fluid #5
I can tell you this and it came from the mechanic that set up my 5030. He told me that Valvoline makes UDT for Kubota. You might try them for more information.
Daryl
   / super udt hydraulic fluid #6
Chevron Synthetic All-Weather THF meets the specifications for Kubota Super UDT.
   / super udt hydraulic fluid #8
The Amsoil ATH is a cross for the Kubota UDT.
The Amsoil ATH is ISO46/SAE30
Dave
   / super udt hydraulic fluid #9
I know that a search on Super UDT would bring 57,000 results but heres another 2 cents worth. Super UDT has cold weather performance that easily exceeds that of UDT. In fact, it exceeded Amsoils 30 SAE. With the introduction of hydrostatic transmissions, getting a better cold performance hydraulic oil was a necessity. I paid $25 per 2.5 gallon container. My L48 took four containers although I bought 5. That was $100 or about .003 of the value of the tractor, it's your call. I think that the oil from Amsoil or Chevron etc. would also be perfectly suitable. If you live in a climate where cold is not an issue, I'm sure you can find something even cheaper. Rat...
   / super udt hydraulic fluid #10
This doesn't answer anyones question but....
I changed the hyd fluid on the L3130 and replaced it with a premium xxx Kubota UDT equivilent. Manual says you can use either but they recommend the Super UDT. I noticed right away they everything was noisier. Also there appeared to be a small power loss. Its not cold here either at the moment 50-70 deg.
I will be using the Super UDT at the 400 hour change. That should be about September timeframe when the temps start dropping. At least I can say I tried it, didn't like it. At the rate hours are going on the tractor these days at least the timing works out to go back to the Super.
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
