super A c113 pistons
   / super A c113 pistons #1
farmall49rick
farmall super A
I am rebuilding my 1949 super A c113 engine. I will be replacing the pistons and sleeves to the 3.125 bore. the question I have is with the step top pistons. are these an option to increase compression for this engine or are they spicific to engines origionaly equiped with them. Any information would be helpfull.
   / super A c113 pistons #2
You can use the step head pistons...(called "Fire Crater" by IH...) I've got them in a Farmall 230 and a 140...Both of those were the 123cu in engines..you can also get the same ones for the SA...they just have thinner sleeves...It may only add about 5hp though..BobG in VA
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
