Sunshade canopies
/ Sunshade canopies #1
check 6
South Texas
BX 2680. Front bucket, grapple, pallet forks, box blade aireator 008-5 excavator ZD 1211 mower RTV 500
Ideas and pictures for canopies on BX tractors and KX008 mini excavators
/ Sunshade canopies #2
The canopy came with the tractor, I believe it is made by A&I Products. It's all metal, nice setup, but I have dented it in the back while mowing and rolling into a tree slightly while backing up.
/ Sunshade canopies #3
Save yourself several hundred $$ and make your own. Use a used golf cart top, some 1" steel tubing for an "L" bracket with an angle brace on each side and U-bolt it to your ROPS.
Mine shown to the left cost me $30.
/ Sunshade canopies #4
Over the decades I've found nothing blocks the sun 100%, there is always sun on you with a turn of the steering wheel.
I wear a wide-brim hat and use sun-screen; wear a long-sleeve shirt and long pants. A canopy or enclosed cab is only good where there are no trees/overhead obstructions. Much of the time I have my ROPS down for working under tree limbs.
/ Sunshade canopies #5
make your own if you know how to fab ,
mine was a fiberglass cover for a 6ft chevy bed
used 2 inch muffle pipe for the bends and old a
angle for the rails , to keep cool in 90 degree weather,
i used a 12 volt fan from a car does a super job .
/ Sunshade canopies #7
the fan was out of a chevy lumina, there was 2 fans I just used one
and still have the other for a spare, used the fan frame that was predrilled
for holes, marked the spot on the roof, drilled used 3/8 carriage bolts 6 inches
long, used i/2"pvc as a spacer to hold off the top of the roof, a good mod that will keep you
cool !!! i did wire through a relay from the battery to a toggle switch
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
DITCH WITCH 3700 TRENCHER (INOPERABLE) (A67714)
DITCH WITCH 3700...
Wacker Neuson WP1550 Walk-Behind Vibratory Plate Compactor (A66734)
Wacker Neuson...
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
