Box Scraper Sundown teeth
   / Sundown teeth #1
pjames
Does anyone know a loa of the teeth for sundown 6' bb? Its 5-6 years old, i bought it without teeth.
   / Sundown teeth #2
For every box blade I have seen the teeth are the same size. Most have notches on the front portion that lock on the frame and secure with a pin from the top. The other type have holes in the middle that pin in from the sides. Look at your BB and see if it has option to put a pin in across the scarifiers and if so buy the ones with holes other wise it is the notched type. They are all the same size and should be available from your local tractor dealer or from Agri-Supply.
   / Sundown teeth #3
Agri-Supply has 16 inch and 18 inch box blade teeth. Measure your box blade from the top of the mounting tube to the bottom of the sidewall and see which will go down far enough past that for you. Remember the top of the tooth will be an inch or two above the top of the mounting tube.
Bruce
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
1262 (A50490)
1262 (A50490)
1240 (A50490)
1240 (A50490)
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
RoGator 844 sprayer (A50490)
RoGator 844...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
