Sump return john deere 4710 tractor
   / Sump return john deere 4710 tractor #1
AJT
Hello, I am adding a Down Pressure assembly to my post hole digger and I need the Hydraulic return to go to the sump. The problem is I do not know were the sump return is on the tractor (JD 4710), does any know and/or have a pic of were it is. Thanks for your help!!
I talked to a guy at a JD dealership and he said any port on the rear axle that is just a plug can be used as a sump return. I have some photos of the back of my tractor on the right rear.
   / Sump return john deere 4710 tractor #3
The hex plug below the RH rockshaft is the one JD uses for the backhoe return.
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2000 Chevrolet C8500 Flat Bed with a Moffet Kit - CAT 3126 Engine! - (A55218)
2000 Chevrolet...
2015 New Holland Boomer 47 4WD 45HP Utility Tractor (A55787)
2015 New Holland...
2014 MOROOKA MST 3000 VD TRACK DUMPER (A52705)
2014 MOROOKA MST...
