suitcase weights
/ suitcase weights #21
I found these. $53.12 each with free shipping. If you buy 24 they are only $40 each
42 lb Suitcase Weight 8 pack FREE SHIPPING8 - OMNI Mfg LLC
/ suitcase weights #23
View attachment 396089View attachment 396090
With FREE shipping, that is a great buy!
Each weighs 42-lbs. I have two already on my YM2610. I can fit two more like these up front. These are the JohnDeere/Yanmar types in the green pix.
The two pack comes in at $115 still with FREE shipping!
42 lb Suitcase Weight 2 pack FREE SHIPPING8 - OMNI Mfg LLC
These will fit a majority of Yanmar YM series and many of the JohnDeere CUTs.
The lowest price I had ever found with FREE shipping was $64+tax at my local Lowes. But, you have to order on-line and do store pickup.
/ suitcase weights #24
I got a pipe and filled it with free lead and had a buddy weld brackets on it. Not as tractor like and can get inthe way if you turn close to trees and such but for free :)
/ suitcase weights #25
I like free. My Bumper full of Free Fishing Anchor Lead I collected at the local lakes. I believe it came in around 55-60Lbs. :D
/ suitcase weights #26
Sweet. I've seen people use PVC pipe with cement and end caps too. Just that cement isn't as heavy as finshing weight. The PVC pipe brackets are easy to get and mount to the front tractor bar.
I do like how you colored matched the square iron tube to the tractor. :) Plus, you can attach if needed a come-along to the front or a battery operated winch. Better options than the tractor weights just hanging there IMO.
/ suitcase weights #27
After using a boom pole to move my 5ft finish mower and having the front wheels raise off the ground I discovered front counter weights were needed I made a 32X16X21 tool carrier bolted to the front weight bar and use 15X15X4" cement blocks avg weight 70lbs each got them FREE 12 of them also built side bolt on frames for my box blade adds 140lbs works great.
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
