suitcase weights
   / suitcase weights #11
Now you got me thinking and I called the local JD dealership they priced me at $90.00 each back in December and had to order them , That's why I started looking else where Now 5 minutes ago they priced me at $35.00 each and had 9 in stock ?? I guess they must have an overstock ?? Still glad you made me think about this today ,Thanks everybody gotta go warm up the truck !
Now you're talking!!! .83 per lb. Not bad at all for new weights that are the specific dimensions and weight that you want!!!
   / suitcase weights #12
just noticed that the weights on the link are "REAR" weights? Did not know there were rear weights, are these the same one like in the pics and that hang on a front bumper?
   / suitcase weights
Yes. They fit great on the front of my ym2000.
   / suitcase weights #14
Maybe listed that way because they only sell lawn tractors ? I want this style because I can hang them in front or off the box blade .
   / suitcase weights #15
we sold 25lb jinma weights for $25 the best shipping was USP flat rate box
   / suitcase weights #16
was either over the past weekend or earlier this week I seen some on CL for sale here in Ga, it had to be either Athens or Atlanta as they are the only 2 places I look at, Might be worth looking them up if still available, I suppose the drive to get them might be cheaper than the cost to ship them,
if you still need them I'll try looking back for them,
Oh they are closer than I remembered 5 miles up the road,:D
http://athensga.craigslist.org/bar/3540824348.html
   / suitcase weights #17
Look on search tempest it will search cragslist and ebay in a set circle around you, you set the miles. You would be surprised what is out there.
   / suitcase weights #18
I got 240 lbs of weights that had been on a tractor with a larger bumper, and made a shim from a 4x6 faced with steel plate to match up the mounting dimensions. Everything fits snug and is secured with bolts. Here's a photo from a couple of years ago.
I subsequently found and adapted iron weights for the rear wheels too. Thread with photos - adapting the rear wheel weights to fit.
Then my neighbor gave me 200 lbs of weights from scrapped exercise equipment. Each is the size of a paperback novel and weighs 10 lbs. I used two of them to fill the cavity on the front of my front weights. If you stand back far enough - it doesn't look too bad. :D
Total iron ballast 410 lbs for $120. Plus filled tires. Finally I have enough traction to haul my watering trailer (weighs more than the tractor) uphill.
   / suitcase weights #19
Total iron ballast 410 lbs for $120. Plus filled tires. Finally I have enough traction to haul my watering trailer (weighs more than the tractor) uphill.[/QUOTE];)
Here's my on the cheap extra balast thanks to a few of our local lakes. It's filled with lead from a collection of lost anchor's. Hefty 75Lbs.easy. Only 2wd and since I just needed to add for when the FM. is attached and trailering. Also make's for a great bumper.:confused2: :drink:
   / suitcase weights #20
Have you already bought weights ? If you'er close you could drive over and pick them up. Call Fredricks in NO. AL. He use to sell them. Don't know the price
TRUCKING INFO (A50774)
2016 CROWN RR5210-35 FORKLIFT (A51222)
2016 CROWN...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
