Suggestions To Lighten Rear Ramp.....
   / Suggestions To Lighten Rear Ramp..... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I have had a '18 and '20 foot trailer for years and have recently purchased a small 8 x 10 unit for collecting brush/small limbs on the place and to also trailer my riding lawn mower to our weekend place. It has a 4x8 mesh ramp on the rear that folds in the middle when stowed in the up position the rear unit is only 2x8 feet. The good news is that this hinged rear ramp is very well made. The bad news is that it is very, very heavy and folding it out once and then letting the whole unit to the ground is a huge pain. I am no weakling but it is a chore. I never tried to manually open the ramp at the dealership because it never dawned on me that a metal mesh ramp would be so heavy. I am at a loss as what I might do to make it easier to open and close. Any ideas?
   / Suggestions To Lighten Rear Ramp..... #2
Have you looked at the Gorilla-Lift ramp-gate assist's?? If not, look at some of their video's on their website, I think there are some on youtube as well.
https://www.gorilla-lift.com/
   / Suggestions To Lighten Rear Ramp..... #3
We make trailer gate aids out of PVC pipe and a set of garage door springs.
There is a commercial product called Gorilla Lift.
Chris
   / Suggestions To Lighten Rear Ramp..... #4
An option may be to copy one of the old U-haul leaf-spring assisted tailgate setups. It's a little bit cleaner above the top rail of the trailer, but would require fabrication. If more lift were needed a pair of springs could be used, or a stiffer leaf. These pictures are of a homebuilt version, taken from Self Lifting Trailer Tailgate | DIY METAL FABRICATION .com . Numerous other similar designs abound:
   / Suggestions To Lighten Rear Ramp..... #5
Have the Gorilla Lift system on my tailgate. Heavy Duty gate with 2x2 square tubing that has to handle 4500 pound tractor. Gorilla Lift makes 200 pounds feel more like 40.
All the ideas in posts above are great but this gate is not a one piece unit as in everyone's pictures. This is two pieces hinged in the middle horizontally. I"ll post pictures tomorrow morning. It is a very awkward set up.
   / Suggestions To Lighten Rear Ramp..... #7
I had your description in mind when I suggested the leaf spring style; remember that if you are able to "over spring" the lower hinged portion, it will be lifting one side of the upper portion of the ramp for you. I'm not saying it's ideal, but I have used spring assisted gates like what I think you're describing before, and the assist on the lower half was sufficient. If you still need more, a spring on the hinge like this would help: Left Hand Torsion Ramp Spring, 6.3 in-lbs. #08-608-L
   / Suggestions To Lighten Rear Ramp..... #8
I just finished cutting off my homemade around 300+ pound, 20 year old, extremely over built, rear ramp/gate off my 16' trailer. Getting too old to use it in the future. Bought a set of 5k/axle aluminum ramps and redid the rear of the trailer to accept them. Left the two bars on the railing that used to hold the gate closed for a future light removable rear gate...
The leaf spring system might work but in your picture it protrudes out behind the gate when the gate is up. The rear half of my gate folds down behind the front half and they must pancake together and touch to secure them to the trailer. In other words when folded up in the vertical position there is no space between the two halves and the end of the spring would prevent securing them to the frame of the trailer for driving down the road. Tomorrow I will go out and look again to see if the leaf spring idea could be modified to work on this set up. Monday I"ll phone the manufacturer to see what they say on the subject. I doubt I am the first that thinks this set up is too heavy to open and close. If the rear ramp was one piece it would be a bit easier but having to bend over and fold the two halves open and closed while lifting is another story.
   / Suggestions To Lighten Rear Ramp..... #10
Why not just fix both halves together or better yet get rid of the gate and go to ramps?
Chris
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
John Deere 2020A Progator (RUNS) (A50774)
John Deere 2020A...
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
International 3500 Backhoe (AS IS) (A50774)
International 3500...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
