Suggestions on what to look for when buying used?
   / Suggestions on what to look for when buying used? #1
tommyz270
Bella Vista, AR
Still looking...
I'm thinking about buying a used Kubota B7500HSD, 4wd, hydrostat, Diesel, 3cyl, 21hp.
I'm fairly knowledgable with cars and gas engines, but not tractors and diesels.
Does anyone have any suggestions of what to look for, what to look at, etc?
Everytime I start the engine, there is smoke, but I think that's common with Diesel, correct?
Any helpful comments would be appreciated.
Thanks
   / Suggestions on what to look for when buying used? #2
A little smoke is normal for a diesel.
Make sure everything works as it should. Brakes, 3ph, clutch, pto, etc.
Check fluids and make sure none are low. Low fluids indicates a leak or poor maintenance on the unit.
Make sure hydraulic fluid is clear and not milky which would indicate water.
Crawl under and check for any visible leaks, or oily spots.
check the tires for wear/dry-rot. If the rears are loaded check the condition of the rims.
If it has glow plugs or a block heater verify that they work or it'll be a pita when it gets cold.
See if he has any service records of when the oil has last been changed etc.
If he did it himself look at the oil filter, some people write the date of when it was last changed on the filter.
Make sure the tach works, cause if it don't the hours on the machine probabally won't be right. And if its close to 6000-7000hrs its probabally close to rebuild time.
Yep I think thats about it.
   / Suggestions on what to look for when buying used? #3
While people are answering questions... what is a MMM? I take it, it's some kind of mower component, but what?
   / Suggestions on what to look for when buying used? #4
Short for Mid Mount Mower.......... as opposed to a RFM (Rear Finish Mower).
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
UNUSED RAYTREE RMDM72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2001 CATERPILLAR 908 LOADER (A51406)
2001 CATERPILLAR...
