Suggestions on oil for BX25
   / Suggestions on oil for BX25 #1
Chugbug
Central Ohio
BX25
I'm getting ready to change the oil in my BX25 and interested in what everyone is using in their 25's. I've been using Kubota brand 10-30 but would like to find a synthetic. I've used the search engine but couldn't find any conversations on oil types. Any thoughts or does anyone know where I can find a thread on oil. Thanks all!
   / Suggestions on oil for BX25 #2
   / Suggestions on oil for BX25 #3
Just about any forum that has anything to do with gas or diesel engines has discussed syn vs dino 'ad nauseam', so get ready! This thread could go on for a month or a minute. Given that, I have a BX and am happy using Shell Rotella t6 full syn.
I know there's a lot of different thoughts out there as well as opinions but just wanted to see what other Op's are putting in their BX25's. like i said, I've been using Kubota 10w-30 but that stuff is high compared to other brands and I would like to use synthetic from here on out.
   / Suggestions on oil for BX25 #5
Shell Rotella T-6 full syn been happy with it:cool2:
   / Suggestions on oil for BX25 #6
I've been using RPM DELO 15-40 for 50 years in everything I have ever changed oil in. It originally was formulated for stationary and heavy duty diesel engines. Meets the specs for Kubota and then some. I have never been sold on the high price for synthetics so why start now.
Ron
   / Suggestions on oil for BX25 #9
I run Amsoil 10w-30 in mine. I've also heard good things about the Rotella synthetic also.
   / Suggestions on oil for BX25 #10
I use Shell Rotella T6 in everything except my gas lawnmower and then it is T5 although I think the T6 would work but I have several gallons of T5 to use up so the lawnmower gets it. It exceeds all the specs and is reasonably priced at Walmart. When I find it on sale I usually stock up with several gallons. My tractor uses 2.5 gallons on an oil change so I keep at least 5 gallons in stock.
The question of whether synthetic is better than dino for my very low hour per year (that is my oil change schedule ) is questionable but for my once a year oil change, I figure that a few bucks more isn't going to bankrupt me and since I do change only once per year, I want to use the best lubricant that I can that is good for all weather conditions at least the conditions that I have. I use the 5W-40 and it meets all the lows and highs for the temps here and then some.
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
