Suggestions of what size and model for a Kioti tractor
   / Suggestions of what size and model for a Kioti tractor #1
Bedlam
Greetings.
I am considering a new replacement for my Ford 1720 tractor. Its been so good to me I am not sure I can part with it.But if I can get a real good trade value then I might consider it.
Anyways considering the 1720 here is what Id like to get from a kioti model.
I would like to upgrade to a tractor that's more power but also mostly so that I can handle a larger Backhoe. (liberty 8 foot.) I presently have a 30 plus year would woods that's been very good to me. In fact I might not trade that in as a package with the tractor.
I would be opting for the AG tires that I don't think is a problem. Also possibly a cab. although that's negotiable.
I want a GEAR transmission defiantly. No question on this part.
there seems to be so many models Im unsure what would be a good one to meet the needs.
Any suggestions would sure be appreciated. thanks
   / Suggestions of what size and model for a Kioti tractor #2
Well, not sure if you're aware of this, but the new models just released are what's known as "tier 4" tractors. That is, they meet the newest standards for emissions set by the epa. Usually it's a diesel particulate filter, or DPF that does the job. So far (hasn't been long) no negative experiences reported, but it seems to add about 3-4k to the price tag. If I were you I'd be looking at the DK 40,45, and 50 models. Not sure if you can get them with a power shuttle, but someone else knows I'm sure. If I wanted gears, I'd have a power shuttle for sure. That's what led me to look at the DS series, but if you want a cab that's out.
Happy hunting, keep us posted.
   / Suggestions of what size and model for a Kioti tractor #3
The CK's will only take a 7.5' hoe. So, I think you are looking at a DK. I think most can be had with manual trannies. The DK40 is the best value, and if you don't need more HP, that's the way to go. The DK cab is real nice too. I have a CK25 synchro shuttle. I like it.
   / Suggestions of what size and model for a Kioti tractor #4
You'll want a DK40SE or larger to take a set up from what you have.
   / Suggestions of what size and model for a Kioti tractor #5
A Kioti dealer told me just today that Kioti won't have to conform to Tier 4 emissions standards until next year...so this years models are still Tier 3. He full of hot air...?
Something about having enough "credits" :confused:
   / Suggestions of what size and model for a Kioti tractor #6
Non-conforming, not-tier 4 tractors are going away. Kioti is proud that their NX series doesn't knock the tractor out when it does a regenerative cycle. The NX series does not disable use during regeneration cycles. However, during a regeneration cycle, the engine must remain running. The operator may bypass the regeneration cycle up to three times in order to shut the engine off, but after being bypassed three time the regeneration cycle will put the tractor into a limp home mode during regeneration.
Kioti, Massey and Kubota are the only guys selling compact utility tractors that conform to tier 4. Expected life of the particulate filter is 3,000 hours. Anybody here not working commercially who bought a tractor new put on 3,000 hours on their tractor?
And if you did, in how many years?
The best thing about their 4 engine is that they are all much quieter!
   / Suggestions of what size and model for a Kioti tractor #7
Don't know about all the others, but LS's XR series are Tier IV compliant as well.
Thanks for the reply My goodness The one thing I hadnt considered. (emmisions).
I suspect that this factor alone is going to cause me to decide to keep my present tractor just on that fact alone. Sad to say. Sort of like how I hold onto my older truck (non emissions).
I find this totally rediculious with these small tractors as they aren't run in most time very much considering . And to add a huge dollars to it only hurts the economy in my mind.
I know I could draw alot of people complaining about fresh air but come on give me a break. 40 maybe 50 gallons at most a year ?I cant be that bad can I?
Anyways back to my thoughts. Im sort of leaning now to an older (10 years) full size backhoe. As they are much less money And Im really looking to trade the tractor so i can get a larger backhoe.
Ill just burn allot more fuel to do what I wish to do. But those older ones dont have the pollution garb on them.
But the Kioti is sure a good looking tractor and I like the rear remote (3 pt) lever..
WOW
   / Suggestions of what size and model for a Kioti tractor #9
WOW
You can still get Tier III machines (no emissions control equipment), but they are starting to dry up. If you talk to a Kioti dealer about a DKXXSE model, it will be Tier III, so you wouldn't have to worry about emissions stuff. The NX series does have Tier IV compliant emissions equipment, so find a DK and you're set.
   / Suggestions of what size and model for a Kioti tractor #10
i vote dk40 as well
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A55787)
2025 SDLL30 Mini...
