Suggestions for ROPS lights
   / Suggestions for ROPS lights #1
Speedy7
North East MA
Kubota BX23
Open to suggestions for best way to mount a couple of lights on the ROPS without drilling holes. I've seen solutions that utilized C-clamps that clamps a bar with the lights onto it. Would love to see other elegant solutions that members here have improvised. Pictures appreciated. Thanks!
   / Suggestions for ROPS lights #2
I mounted 4 fog type lights to my ROP's using aluminum plates. I guess you would call them clamp on. Click Here
   / Suggestions for ROPS lights #3
Im drilling mine. Nothing looks as neat and clean as "hidden" wiring...and if 4-6 1/4 inch holes in that ROPS destroys its integrity...then it wasnt made worth Jack Squat to begin with!
   / Suggestions for ROPS lights #4
Clamps like Rons or U-bolts are the easiest.
   / Suggestions for ROPS lights #5
Like THIS . I've taken some flack, but the install is clean, SAFE and doesn't look cobbled. /forums/images/graemlins/tongue.gif
I used to build ROPS units for C-NH at a machine shop where I worked and I feel completely safe with the modification I did.
   / Suggestions for ROPS lights #6
If you drill your ROPS you may as well discard the ROPS as ANY modification voids ANY manufacturer's warranty.
   / Suggestions for ROPS lights #7
</font><font color="blue" class="small">( If you drill your ROPS you may as well discard the ROPS as ANY modification voids ANY manufacturer's warranty. )</font>
I didnt buy it for the warranty! I bought it to protect my "gourd" in case Im dumb enough to be in an accident! A few , SMALL holes wont affect its INTEGRETY...and thats all Im worried about.
   / Suggestions for ROPS lights #8
</font><font color="blue" class="small">( Like THIS . I've taken some flack, but the install is clean, SAFE and doesn't look cobbled. /forums/images/graemlins/tongue.gif
I used to build ROPS units for C-NH at a machine shop where I worked and I feel completely safe with the modification I did. )</font>
You've got it my man..dead on... /forums/images/graemlins/grin.gif
   / Suggestions for ROPS lights #9
I prefer welding. I also don't care about the warranty on the ROPS. I also believe mine is safer now with the extra metal, as it would slow the fall in a rollover. The smaller pieces of metal will bend and absorb energy before the main rops takes all the force.
My lighting project is on this web page
   / Suggestions for ROPS lights #10
I put mine on the side of my B7610. Got some magnetic light mounts fromt Tractor Supply Co. (the round yellow ones) and stuck them to either side of the ROPS right on the hidge bracket where it folds. The wiring was already there (a +12V under the seat) so all I had to do was drill a hole on the fender (the black plastic where the 4wd and 3pt handles are) for a toggle switch. All works fine and they are easy to remove when I go into the woods. (I put quick connects on the wires near the lights)
Wanna add a rear light and 2 more on top of the front guard also.
good luck
EZ GO EXPRESS S4 EFI GAS GOLFCART (A51247)
EZ GO EXPRESS S4...
CAT E70B Excavator (A51573)
CAT E70B Excavator...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
