Suggestions for new tractor and attachments...
   / Suggestions for new tractor and attachments... #1
Twrayw
Oxford, NC
None
I don't have much tractor experience and need some suggestions. I'm sure I want a Kubota, just not sure which one would be a good fit for my needs.
I have 17 acres with my homesite, 1/2 wooded, 1/2 in mostly grass. I plan on using the tractor for a fair sized garden, long gravel driveway maintaince, some light clearing, and moving wood around.
After some research it looks like a L3800 with front end loader would be a good start. Also need some suggestions on what attachments I would need for a garden.
Thanks in advance for any suggestions....
   / Suggestions for new tractor and attachments... #2
Welcome. IMO that is an excellent choice. I have a L3200hst that I use on 100 acres for pretty much the exact same purpose you noted. I would have preferred to get a larger tractor but that is all that would fit in the barn without removing the loader. Was thinking it would be too small but it has been perfect. A larger bush hog would be nice on occasion but other than that it is all I need. I have a box blade I use for our 1/4 mile driveway, a tiller for food plots (use for garden) and an auger as well. You may want to consider the quick attach for the loader. Have a set of pallet forks that come in more than handy. The L3200/3800 is light so make sure you have the rear tires filled.
   / Suggestions for new tractor and attachments... #3
Good advice far.Roto-tiller,box blade(with scarifiers),may-be an inexpensive($150.00) middle buster for breaking ground in the garden.Brush-hogs are nice for rough cuts.Most will advise to load the rear tires for ballast.I would suggest the HD bucket,a couple weld on hooks and may-be a tooth bar(a little better digging).
   / Suggestions for new tractor and attachments... #4
why not step up to the mx5100 an have all the power youll need todo anything you want.an get a 3pt tiller to work your garden.an a boxblade to maintain your driveway.
   / Suggestions for new tractor and attachments... #5
Twrayw,
Define your garden size, 50'X50', 50'X100'? If less than 50'X100', you may be money ahead to consider a walk-behind tiller rather than implements for your tractor. You can easily tie up $1000 and much more on plow, disk and/or tractor mounted tillers and still have need for a walk-behind for weed control.
I think the L3800 with loader is an excellent choice. I would especially recommend 4X4.
Do you receive any snow?
   / Suggestions for new tractor and attachments... #6
I'll put my 2 cents in. I use my tractor for all of the things you mentioned. I wouldn't be without my HST and I've owned or used gear, shuttle shift, and HST. I love my 6ft 3 point tiller. The box scraper and blade do a pretty good job on the 1/4 gravel drive. My 37 hp runs the 6ft rotary cutter just fine in the tallest pasture.
I will also say, I bought my tractor used, 4 years old with under 400 hrs. at quite a discount compared to new. It's still worth almost what I paid for it 10 years ago with under 700 hours on it. If I had to do it again I'd do it the same way.
Kevin
Thanks for the imput, we only get a significant snow every 2 or so years, but it will be nice to have a tractor when we do get some snow.
Also looking at the B series, what is the difference between the B3200 and the B3300SU besides the mid point PTO on the B3200.
   / Suggestions for new tractor and attachments... #8
Twrayw,
I asked about snow because a rear blade works much better on/in snow than a box blade. A rear blade with end plates does ALMOST as well as a box blade on moving dirt. For myself and my area, snowbelt, I would choose a rear blade first and add a box blade later if needed.
Echo Weedeater, Stihl Pole Saw & Predator Gas Auger (A50123)
Echo Weedeater...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
Cub Cadet LX42 XT2 Lawn Tractor (A53117)
Cub Cadet LX42 XT2...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
