Grading suggestions for Box Blade for BX 1850
   / suggestions for Box Blade for BX 1850 #1
ghamden
Looking to purchase a Box blade for my kubota bx 1850 any suggestions on size and brand
I am looking at a King Kutter 60" From TSC for 399.95
I was concluding the same thing looks as if 48" would be more the right size.
   / suggestions for Box Blade for BX 1850 #4
I have a King Kutter 48" XB blade on my 2230 and it works well, I would not want anything bigger.
   / suggestions for Box Blade for BX 1850 #5
I don't know. I just bought a 60" for my BX2230 and we are 60% clay, 18% silt for 78% hard pack and I'm pullin' it. Scarifiers down, diff lock engaged and 4WD and just lay it into 'er. Might just be scrappin' the surface, though! (no pun intended!) I got it from these guys:
http://www.westwardparts.com/wwparts/MainDisplay.aspx?CountryCode=cdn
She will hang up on roots and stuff, causing you to back up 3-4" and get a little run at it, but I think it would do that with a 48", anyway.
Regards
   / suggestions for Box Blade for BX 1850 #7
bx23barry said:
I have a gearmore 48" blade and all I can do in my hard pan with a full box is spin tires but I am really not much of an operator.
That sounds about right. I learned to start accelerating when about 3/4 full or so to get the momentum to pull the full box any distance. (4x4, diff lock, of course)
   / suggestions for Box Blade for BX 1850 #8
Ditto the "King-Cutter XB" 48".... bought it at Tractor Supply on sale for around $345 for my BX...works great and seems to be well made. It's designed specifically for "sub-cut" tractors.....anything larger and you will start breaking things on your BX...just my opinion.
   / suggestions for Box Blade for BX 1850 #9
As was mentioned, 48" is the size you need.
Ive got a 48" Landpride BB. It was pricy but is good quality. For a SCUT, Im sure a when old BB would work just as well.
   / suggestions for Box Blade for BX 1850 #10
Traction has been my biggest limitation. I have a 48" and don't think I would go any wider. With the scarifiers down, I can cut a nice little wedge, but it is easy to stop the tractor with too much cut. Stop, raise it a bit, go forward, rinse, repeat. On the surface, a 60" seems like it would help production, but in the end, I don't think it will be as effective.
Duetz Power Unit (A50120)
Duetz Power Unit...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
