Suggestions for a good sawmill
   / Suggestions for a good sawmill #1
Scott_in_WVA
Guys,
I am thinking about buying a sawmill to put on my farm....What is a GOOD type to go with... I am open for suggestions and comments please...
Thanks
Scott
   / Suggestions for a good sawmill #2
Guess it depends on how much wood you plan on sawing, how large the logs are and the most important part how much you have to spend on it.
But to get started a manual band mill might be something to look at.
Gordon
   / Suggestions for a good sawmill #3
Today there are many small saw mills available, most of them band mills. The correct mill for you depends on several factors.
What type of wood are you primarly intrested in sawing, softwood or hardwood?
What size and legnth needs will you have?
How much do you want to spend?
How much do you plan on cutting per day?
How long do you plan on owning the saw mill?
How portable does it have to be, will you bring the logs to it or it to the logs?
How will you load the logs onto the mill?
There are many portable band saw style mills offered today starting around $3,500 all the way to $50,000. There are several rotary mills offered today which if I remember right start around $8,000 and go up to $25,000 or so.
Lucas makes an impressive rotary model that I believe is the least expensive. It is all manual neaning you have to push the saw through the log like many band saw mills. I watched one cut lumber and it did a fine job. The log rested just about on the ground making log loading easy.
Most band saw mills are similar, the carriage runs along a track. Some have power feed and some are hand feed, depends on how much you want to spend and how much you intend to cut in a day.
I have a rotary that I have owned for over 20 years made by Moble Manufacturing Company. It has worked well for me cutting a mix of soft and hard wood.
If you plan on doing a lot of cutting with a band mill consider buying an edger to go along with it. The log loading options and power feed are nice too.
Best thing to do is visit a few people who have a small mill like what you want and watch them operate it and ask a few hundred questions. They have to be easy to adjust and operate. Saw dust build up on the track is one of the things to look for as this will cause an inconsistant thickness.
There are several different types of blades and teeth which make a difference cutting hard, soft, or frozen wood. There is a lot of good imformation out there, good luck.
Randy
   / Suggestions for a good sawmill #4
Scott,
The exact name escapes me at the moment but there is a
magazine titled something like "Small woodlot and sawmill"
that I have mentioned in previous sawmill threads. We had
a sawmill discussion in the last few months that might be
interesting to read if you have not done saw already.
The magazine I mentioned has shootouts of the various
sawmill brands and rates them on production and price. One
of the latest issues just had a shootout comparison.
If I can remember I'll try to look at my latest issue and see
if there is a web site for the magazine.
Later,
Dan McCarty
   / Suggestions for a good sawmill #5
There is some useful information at <A target="_blank" HREF=http://www.sawmillexchange.com/>The Sawmill Exchange</A>.
   / Suggestions for a good sawmill #6
As mentioned before go to <A target="_blank" HREF=http://www.sawmillmag.com>http://www.sawmillmag.com</A>. I have been a subscriber since issue #1 and love it.
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
2013 Mahindra MPOWER 85P 4WD Tractor (A53117)
2013 Mahindra...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2016 HItachi XZ300LC-6 (A47477)
2016 HItachi...
