SUDT in TZ25DA
   / SUDT in TZ25DA #1
mjonesnh
Platinum Member
Tennessee
TC34DA
Has anyone on TBN used Kubota SUDT in their New Holland hydro. Mine has 84 hrs. and is not getting any quieter with the NH 134d oil. Someone told me this may help reduce transmission noise, especially when cold? Thanks!
   / SUDT in TZ25DA #2
Try Amsoil synthetic trans/hydraulic fluid. Maybe cheaper, and a better fluid.:rolleyes:
   / SUDT in TZ25DA #3
134 is about a 30 weight base oil. Most New Holland dealers also have Case's Ultra Hytran available which is around a 10 weight which should help in cold weather. Depending on storage and use often condensation will take it's toll on oil long before even natural oils will wear out much less synthetics. Were we live often just two years and you have to change oils not do to the hours but because of too much moisture in the system causing freeze ups.
   / SUDT in TZ25DA #4
I don't think the Amsoil synthetic trans/hydraulic fluid meets SUDT specs, just regular Kubota UDT.
   / SUDT in TZ25DA #5
The folks at Messicks told me that the Case fluid (Hytran) cannot be used in my NH TN70A. Not sure if this is true for TZ25DA.
Bob
40ft High Cube Shipping Container (A51573)
40ft High Cube...
12 Yard Rolloff Container (A51573)
12 Yard Rolloff...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
