SUDT in TZ25DA
   / SUDT in TZ25DA #1
mjonesnh
Platinum Member
Tennessee
TC34DA
Has anyone on TBN used Kubota SUDT in their New Holland hydro. Mine has 84 hrs. and is not getting any quieter with the NH 134d oil. Someone told me this may help reduce transmission noise, especially when cold? Thanks!
   / SUDT in TZ25DA #2
Try Amsoil synthetic trans/hydraulic fluid. Maybe cheaper, and a better fluid.:rolleyes:
   / SUDT in TZ25DA #3
134 is about a 30 weight base oil. Most New Holland dealers also have Case's Ultra Hytran available which is around a 10 weight which should help in cold weather. Depending on storage and use often condensation will take it's toll on oil long before even natural oils will wear out much less synthetics. Were we live often just two years and you have to change oils not do to the hours but because of too much moisture in the system causing freeze ups.
   / SUDT in TZ25DA #4
I don't think the Amsoil synthetic trans/hydraulic fluid meets SUDT specs, just regular Kubota UDT.
   / SUDT in TZ25DA #5
The folks at Messicks told me that the Case fluid (Hytran) cannot be used in my NH TN70A. Not sure if this is true for TZ25DA.
Bob
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
Massey Ferguson 9250 (A53472)
Massey Ferguson...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
20ft Utility Cargo Trailer (A51572)
20ft Utility Cargo...
