xBBx
Hi there,
Looking for some help or advice on this one. I have a Kubota m8560 with a single set of rear remotes and a Kubota FEL.
It's got about 300 hours on it, and I've owned it since new (few years now). I check the hydraulic level on the dipstick near the PTO regularly.
For the last 250 hours or more, it's been right where it needs to be on the stick. I typically have the rear hooked up to an 8ft brushhog, single hydraulic to raise and lower.
So, the other day I noticed a hydraulic leak under the cab. Turns out the protective cover got pulled back and the hose was worn. Probably from rubbing on the brush and such. I am pretty sure it was one of the supply hoses to the rear remote. When I operated it, it leaked more.
I checked the fluid and when I pulled out the stick, it started to overflow out of the hole? So I removed the cutter, same thing. I went ahead and replaced the hose, loosing a bit of fluid along the way.
Checked the dipstick and it's still coming out of the hole. Like now there is too much fluid in there? It's not foamy or frothy or anything else. The FEL and rear remotes are not acting funny, plenty of power.
But what is causing the fluid to push up through the hole? It's like there's suddenly too much fluid but I haven't added anything since the 50 hours break in fluid change? Doesn't seem to matter if it is running or not, same fluid coming out of the dipstick hole.
Thanks in advance if you have any ideas.
