Sudden start PTO Montana 5720
   / Sudden start PTO Montana 5720 #1
lerauh
My 5720 PTO has started to engage spontaneously when switch in off position. It may start and stop momentarily or run for several minutes. When PTO switch in on position stays on. Not sure if this a electric switch problem or problem with valve that actual engages PTO. Anybody have similar problem or better yet a solution?
Thanks, Larry
   / Sudden start PTO Montana 5720 #2
If you can locate the PTO solenoid, simply disconnect the wires from the coil. Run the tractor for a while and see what happens. If the problem goes away, you should ckeck your circuits for a stray 12v signal to the coil.
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
UNUSED FUTURE FT-X1200J STAND ON MUD BUGGY (A51247)
UNUSED FUTURE...
