Sudden start PTO Montana 5720
   / Sudden start PTO Montana 5720 #1
lerauh
My 5720 PTO has started to engage spontaneously when switch in off position. It may start and stop momentarily or run for several minutes. When PTO switch in on position stays on. Not sure if this a electric switch problem or problem with valve that actual engages PTO. Anybody have similar problem or better yet a solution?
Thanks, Larry
   / Sudden start PTO Montana 5720 #2
If you can locate the PTO solenoid, simply disconnect the wires from the coil. Run the tractor for a while and see what happens. If the problem goes away, you should ckeck your circuits for a stray 12v signal to the coil.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
LOOK! (A53342)
LOOK! (A53342)
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
