Sudden Overheating... dropped fanbelt?
   / Sudden Overheating... dropped fanbelt? #11
Mine has never overheated but the screen and in between the cooler and radiator need to be cleaned regularly. I just came in from mowing and it is backed up to the garage right now with the bed raised so I can clean it out.
dsb
   / Sudden Overheating... dropped fanbelt? #12
dsb
   / Sudden Overheating... dropped fanbelt? #13
Have you tried mowing with the rear bed slightly raised?
It may help keep your screen cleaner longer.
Yooper Dave
   / Sudden Overheating... dropped fanbelt? #14
Yooper Dave
   / Sudden Overheating... dropped fanbelt? #15
No . Raising the bed was recommended by a Bobcat mechanic. I have a 400 lb. 75 gallon sprayer on the bed during the mowing season and this cuts off even more visibility. I have 80 acres of very steep terrain to mow and have to stop every 3 hours, cool it down, and clean it out. I just mowed 11 hours with the new turbo series c which they loaned me and didn't experience any over heating issues. I like the way it moves up and down the hills and all of its features but it appears I /forums/images/graemlins/crazy.gifmay have a LEMON.
   / Sudden Overheating... dropped fanbelt? #16
   / Sudden Overheating... dropped fanbelt? #17
After my last post I looked at my screen a little closer and noticed there is a gap on both sides. The front and back of the screen have no gap. I assume this is where the debris gets in that shows up between the cooler and radiator. I may get some foam or rubber to fill that in. It would be much easier while I am in the fields to clean the debris off the screen rather than having to remove it to clean out between the cooler and the radiator.
I haven't mowed any pastures yet but I suspect I will not see nearly as much debris on the screen as compared to the CRP ground which is 2+ foot tall grasses.
dsb
   / Sudden Overheating... dropped fanbelt? #18
dsb
   / Sudden Overheating... dropped fanbelt? #19
HI,
They noticed the gap on my machine last fall and put foam rubber around it to fill the gap. I thought it was fixed until this Spring when they came to demonstrate the Brushcat and it overheated again. I have noticed that debris still comes in on the series C TC but is doesn't cause it to overheat. The screen and housing around the cooler and radiator have been totally redesigned. My field is 1 mile from my home and I don't have a hose or air compressor in the field! Good Luck
   / Sudden Overheating... dropped fanbelt? #20
HI,
2013 Express 20' Cargo Trailer (A57148)
2013 Express 20'...
Fork Extensions (A57149)
Fork Extensions...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
SKID STEER ATTACHMENT ROCK SIFTER WITH BUCKET (A58216)
SKID STEER...
2000 GMC Dump Truck (A57148)
2000 GMC Dump...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
