Subsoiler As A Root Grubber
/ Subsoiler As A Root Grubber #1
Currmudgeon
NE Indiana
JD 855
I have about an acre of saplings and brush on my property. Unfortunately, the land is too rough to dare go in with a rotary cutter. The previous owner used it as a junkyard, so all the rough areas need to be explored for metal. This weekend, I recovered two, fifteen-foot long steel ladders, and two ten-foot lengths of 1-1/2 inch steel barstock. Real lawn mower eaters. The less said about the wire the better. /forums/images/graemlins/shocked.gif
Anyhow, the brush has to come out concurrently with the scrap.
The landscape rake will clean the light brush and weeds, but won’t handle the saplings. The log chain will uproot the saplings, but is time consuming. I decided to try using a subsoiler as a grubbing hook. TSC had one of their King Cutter units in stock, and the sum was out this weekend, so I decided to give it a try. It’s been a mixed success.
Spread rooted shrubs and saplings come out very easily. Just hook the tooth into the root wad, lift with the 3-point and drive away. It’s the tap rooted saplings that are a major pain. Skewering them is like trying to pick up marbles in the dark with an ice pick. Actually snagging the root, that you can’t actually see, is the major frustration. It would probably be easier to loosen around them with the hook and then log chain them out.
I discovered that I could drag a surprising number of improbable objects with the hook, until I got cocky and then everything stopped cooperating and ran from the hook. The hook is also useful for breaking up the blackberry thickets so I can landscape rake out the vines and roots.
The brushy areas are pretty rough, with random mounds about 18-inches high. That necessitated a lot of FEL work to flatten the mounds, fill the tractor flipping holes, and back blade everything roughly level. But the subsoiler made it an easy task for the JD-855 to level the ground.
In the process, the brush has snagged every single lynch pin and half the hair-pins out of my 3-point. The thing is now held together with double nutted capscrews and bent nails, and I’ve learned to assemble a 3-point hitch blindfolded. I’ll clean all that up when I switch back to the landscape rake. I also feel like a pretzel, having spent two days with my feet pointed forward, on the pedals, and my head pointed backward, staring between my back wheels.
Two more days of hooking, and I can switch back to the landscape rake and clean out the mess and maybe do a little fine grading.
/ Subsoiler As A Root Grubber #2
I remember a while back somebody had a steel wedge like thing that looked like the head on a corn chopper that had a small enough gage to wedge saplings and then pull them out of the ground. Cleaning the thing out must have been a problem. I tried a search with sapling puller in the attachments forum. Seems to me that it was FEL mounted. Maybe somebody's got a better memory. SteveV This is a busy place tonite! /forums/images/graemlins/tongue.gif
/ Subsoiler As A Root Grubber #3
I have learned how to make a link to a post or picture, but have not learned how to make a link to a thread. One of the threads that i started on this subject was titled "cleaning the fence row is fun now" & can be found under Attachments, dated 04/12/2002.
I got my ideas from other previous post on TBN. There are several versions both for front & rear of the tractor. I have made both and really like the one on the front.
Another implement that would probably help a lot in grubbing the roots, is a tooth bar for your bucket.
/ Subsoiler As A Root Grubber #5
Search for "tree getter"
Kubota BH77 (A64126)
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2020 Deere 670G (A64126)
2020 Deere 670G...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
