priberc
- Joined
- Jun 5, 2019
- Messages
- 162
- Location
- PG BC Canada
- Tractor
- M85 Mahindra w loader 2 x 740 and 1 x 750 BCS with multiple attachments
#1 consideration for cutting cost "you get what you pay for" and how often do you want to replace your well pump?The water pressure dropped sometime last week so I finally looked into it today and the pressure tank is fine, pressure switch is fine but it would only get to 30psi and the pump was running constant so I went further up the line and found a piece of teflon in the flow restrictor, thought it was from the check valve, nope... I do have a sand problem (or did for a few years after I moved in) so the pump apparently can't make pressure anymore and lost a part of it... I bought the house in '14 and the well was put in the year before that so it isn't that old, the well is around 100' deep if memory serves. I lowered the pressure switch setpoint so it turns off at 30psi and on at 20 so it's at least not running constantly anymore...
So, I know I gotta get a new pump, current is a 3/4hp 4" 3 wire unit since it has a control box and I checked and it has 3 wires plus ground... Home Depot has a pump for $479, Lowes has one for $469, Amazon has them for $200 on up... Which way would you go?
If it was installed in '13 is it likely iron pipe or plastic? The roof panel on the pump house is easy to get off so I'm not worried about that. I didn't think of pulling the cap off the tube when I had the check valve off...
Do you need a 3/4hp pump for a 100' well? The old well here is 300' deep and it used a 3/4hp pump. You may be able to go to a 1/2h pump. The price difference may not be that great though.....might be worth looking into
That said the old pump in the well here looked after a family of 6 and a herd of 75+/- dairy cows chickens garden etc etc. The original brushed pump lasted +/- 3 decades before it was replaced the first time. Modern brushless pumps should last much much longer. So IMO it might be an idea to look at the brand of pump you pull out and make sure you don't buy another
