Subject :TIlt or Ramps
   / Subject :TIlt or Ramps #21
<font color="blue"> "I think the weight on the front wouldn't let the bed tilt." </font>
That would depend on how heavy your hydraulic cylinder is.
   / Subject :TIlt or Ramps #22
I might move machines as many as 4 times a day, the speed with a tilt is extremely fast. On rare occasion with more implements I can manage, but since I don't usually move many implements except the one on the tractor, its not a big worry and I haven't not been able to get what I want on it yet. It also works great because it doesn't have to be hooked to the truck to load and unload, unlike a ramp trailer that must be connected. I thought it wouldn't matter to me but after having tilt I found myself unloading without the tow vehcile a lot................just some thins to think about
   / Subject :TIlt or Ramps #23
Hey Johnno;
What size tractor are you loading this way? I"ve only used a manual light duty tilt trailer. What keeps the front end from moving when you drive up on it?
Moon of Ohio
   / Subject :TIlt or Ramps #24
After buying my "little" CK20 and having the dealer deliver it with a couple of impliments, I went shopping for a trailer. Spent almost two weeks looking at everything, keeping in mind that I'd be hauling 2,200 lbs plus the weight of trailer with a 1/2 ton RAM. So I bought a 14' box frame removable ramp trailer, 2 axle brakes, nice trailer, the downside?........... the ramps store underneth from the back and are only 4 foot long! Angle of approach is pretty steep! I drag my box scrapper when loading the tractor! and I haven't even tried it with the rotary yet! So you need to check the length of the ramps (Dummy me!) if they're removable.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2003 Big Tex 10PI...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
