Subframe brackets 4310-4400
/ Subframe brackets 4310-4400
So, back to my original question which was it said it came with the brackets, and they were on a 4400. I want to make sure they will fit my 4310. Also, my neighbor has a Woods 7500 on his Deere with a 3 point hitch mount, and a seperate pump. He says he likes that better than the subframe mount. What do you guys think? Thanks, shyguy6 <font color="green"> </font>
/ Subframe brackets 4310-4400 #23
OOPS where did I get 4210?@@
Yes it will work.
I don't want to say your friend is nuts, but RSA Aint a subframe and it beats a 3 point to death, the pto pump is a real pain and you don't need it on a 4310.
/ Subframe brackets 4310-4400 #24
Yes it will work.
Okay, thanks a lot. Now I know all about how Deere attaches their backhoes. Thanks for the info.
/ Subframe brackets 4310-4400 #27
I hope I didn't offend with the comment about your friend.
The RSA is a lot harder to initially install than a 3 point hoe. But it is much stronger, and far easier to take on and off after inital instal. And the whole setup was designed to work together.
3 point setups are generic, and if you had a less capable tractor, one of those might be a better choice
I have the 47 on a 4310 and can assure you that it is a terrific setup.
/ Subframe brackets 4310-4400 #28
429888 (A61165)
429888 (A61165)
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
10-16.5NHS Skid Steer Wheels and Tires (A61572)
10-16.5NHS Skid...
