SubCompacts . . purpose of box blade implement
   / SubCompacts . . purpose of box blade implement #21
Having hydraulic top and tilt may not be 100% necessary, but it sure is 100% nice!
Adjusting the top link length changes the nature of the box blade. Shorten the top link and moving forward and the front cutting edge of the box is more aggressive, cutting more into the soil - the box fills with material. As the top link is lengthened, the front cutting edge becomes less aggressive, easier to pull, and finally stops digging in, only cutting off the tops of bumps - material is still carried in the box and only deposited in the divots and small low spots. This top link setting is also useful for moving material from one spot to another by dragging the full box with no cutting action. As the top link is further extended, the front blade stops cutting altogether as it is now above the ground - any material in the box is now deposited in a smooth layer behind the tractor as the box empties.
The nice thing about a hydraulic top link in all this is that you can watch what's happening as you adjust the length and get exactly the box action you want. It's dynamic, when using the box scraper to cut, move, and spread material, the top link is being adjusted for each phase of operation. Of course, one could just lift the box with the 3-point to dump or spread, though I don't find that nearly as effective or smooth. I used a manual top link with a box and it's nowhere near as convenient as hydraulic top, so with manual, one tends to make do with how the top link is adjusted rather than stopping, tweaking it, repeat.
The above is reversed when the tractor is moving backwards pushing the box, as the rearmost blade will cut when the top link is lengthened. There is a caveat though, the 3 point hitch is not intended for heavy loading in reverse, so pushing the box should be approached with caution and only for lighter loading. I've never bent anything, but I've heard of people who have.
   / SubCompacts . . purpose of box blade implement #22
I haven't used mine in years. A good scrape blade is much better for smothing gravel driveways.
One of the main points to a box blade is that the box allows you to remove material from high spots and redistribute it to low spots -- something that cannot be done with a simple blade (at least not well). It is the key unique aspect to the box blade and the reason that whole design was invented (and I think it's rather ingenious). The presence of the box allows material to collect and naturally redistribute on uneven terrain. When running down the length of my 600-700' driveway with the top link set just right for smoothing, it's amazing to see the material level in the box fluctuate (ebb and flow is another way to describe it) as I am shaving off any high spots and filling any low spots.
A simple blade has its own set of unique capabilities. Both devices are useful/unique in different ways. There is some overlap, but there are things that are unique about both.
In terms of maintaining my gravel driveway, I do 90% of it with my box blade. Having a hydraulic top link makes it very capable. But if I need to crown or move material from the edges to the middle, there is no substitute for my rear blade, angled in two axes. It is the better tool for that. It's also far better for snow removal. My neighbor uses a box blade to move snow off his driveway, and it's so much less efficient than a rear blade. What takes me two passes with a rear blade -- down one side an up another -- takes him 6-7 passes or more.
S219,
Can you explain how a box blade is used for snow removal? As I understand it . . it can't angle . . so it is straight. It would seem it only drags a path . . and I'm not able to picture how that is helpful. If it angled the snow would be worked to the side. If it picked up the snow it would be a bucket that couldn't get rid of the snow. And your tractor has to go over the snow first before it even gets to the blade. And to try to revetse push snow with the box blade would be terribly inefficient it would seem.
   / SubCompacts . . purpose of box blade implement #25
S219,
You answered your own question. It's not that efficient for snow and neither is a conventional bucket. That's why so many people mount blades on their FEL for snow removal. Where it can work nicely is in combination with a front mounted implement: backup to the edge/door/etc, drop the blade and pull ahead a bit more than a tractor length. Lift the blade and backup thru the pile to drop the front implement behind the pile and push. Saves a lot of turning around. It's almost inevitable with snow removal that some snow will be driven thru, just part of the job.
   / SubCompacts . . purpose of box blade implement #26
S219,
That's about it -- works like crap in my opinion. Snow spills out the top and front, so it takes a lot of passes to clean up.
   / SubCompacts . . purpose of box blade implement #27
I am debating the Kubota BX series vs the B series.
I had the same debate a month ago and ended up buying a Kubota B2650 and have not looked back. The FEL is super handy and now my wheel barrow just sits in the garage, I bought a finish mower for it on craiglist and It came with a 60" box blade which is decent but I prefer a 6-way blade. With a B serries you get a "real tractor" vs a garden tractor on steroids. Everything I read prior to buying says buy the biggest tractor you can for the money, that phisolophy is 100 % correct.
   / SubCompacts . . purpose of box blade implement #28
Thanks wchp14...did you look at the new B2601 vs the B2650? I do think the B series is much better for my needs. Probably some of my uses could use an L series but I do not want the extra size or weight for my work in the woods. Tom R
Greetings wchp14,
You stated . . Buying the biggest tractor you can for the money is the thing to do . . and that theory is 100% correct.
That very well might be your personal opinion . . but you bought a Kubota B series product . . and so your own brand would strenuously object to that opinion . . because they are as yet still the largest sold sub compact manufacturer on the planet.
Kubota would tell you they invented that sub compact market because they saw a staggering need for smaller sizes of tractors. Your B series is a compact . . it too was considered little more than a garden tractor on steroids by full size tractor owners at the time.
My point is . . the B series is a group of fine tractors . . but it is only a small part of the Kubota lineup. Sometimes bigger size is better . . . but many times smaller is more efficient or less brutish or more accurate. Its true in football and in tractors :)
   / SubCompacts . . purpose of box blade implement #30
I've got one on my JDX739 garden tractor! Use it all the time for leveling small areas where my bigger tractor/box blade won't fit.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
GIYI GY-CWG72- 72" HYD CURVED WOOD GRAPPLE (A51244)
GIYI GY-CWG72- 72"...
2022 ESTATE MOWER 6' FINISHING MOWER (A51243)
2022 ESTATE MOWER...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Kubota L2501D (A50120)
