Subcompact with tilt capable rear blade
   / Subcompact with tilt capable rear blade #1
CvilleDukes
Central VA
JD GT275, Kubota BX2380
First time poster here. I知 shopping for a subcompact for mostly driveway maintenance. I致e driven the Kubota BX2380, JD 1023, and MF GC1725. The JD and MF dealer offer a 60 inch rear blade with tilt capability which is a feature I知 interested in. My only concern with the tilt blade is the limited amount of height/lift available with a subcompact. Has anyone used a tilt rear blade with a subcompact, and were you able to fully use the tilt feature of the blade?
   / Subcompact with tilt capable rear blade #2
Here is a video of a BX25D scraping snow with our Awesome 6 way Deluxe Scrape Blade, which tilts, angles, and offsets by simply pulling a pin. More value than any compact blade on the market. We can paint them green, orange, yellow or black!
Travis
   / Subcompact with tilt capable rear blade #3
Keep in mind that the blade is typically 3 or more feet behind the lift arms, so the it will come a lot farther off the ground than the height of your lift arms.
A good heavy duty scrape blade is a good thing to have around for property maintenance. The offset style like the one EA is showing above will let you clean out ditches without having to get the tractor off in the muck.
   / Subcompact with tilt capable rear blade #4
Travis
That is a very nice blade. It is on the expensive side, but scrape blades are one of those attachments where there is a huge gap in performance and durability between lower cost options and higher end blades. Just ask anyone that has watched their $500 Chinese blade fold in half!
   / Subcompact with tilt capable rear blade #5
Thanks, Tenn! Yeah, we only build quality attachments and they're intended for the long haul.
The steel tariffs have really helped to level the playing field(no pun) between USA Quality and the chinese stuff.
Travis
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
378806 (A51572)
378806 (A51572)
HOME MADE SMOKER / FRYER TRAILER (A52472)
HOME MADE SMOKER /...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
DRILLING CABINET (A52472)
DRILLING CABINET...
