cfb
Bronze Member
- Joined
- May 5, 2012
- Messages
- 61
- Location
- Cleveland, Ohio
- Tractor
- 1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
Hello,
I've not heard of reverse tiller direction until I started looking for a sub-compact. At least in the Kubota make, I'm uncertain between the BX2380 and B2301.
This is what I've read here and/or heard by Messick's and others:
a. a reverse direction takes more HP
b. a reverse is better for established gardens - provides a nice finish at the end
c. reverse is more aggressive, leaves a deeper, cleaner seedbed, in fewer passes
d. forward is ideal when require shallow till depth
c. Kubota dealer told me that all tiller manufacturers are interchangeable between tractor brands as long as it is with a Cat I hitch. I have to find out yet the difference between a full Cat I and a limited Cat I.
I have an established garden, so only its a maybe if I'll till up new ground which I may if making swales. Even though I've been improving the soil for 30 years, it is far from soft loam. I plant a cover crop each winter.
I have a old ford 16HP diesel lawn/garden (mow/plow snow/rototill) that I'm replacing - very difficult for parts now) that did a pretty nice job of tilling and when soil is right, I get a nice smooth planting bed. However, in the past - not sure if that is why I replace the shaft end bearings, I added a sand sack to try and penetrate a bit deeper. I have a similar age 448 Ingersoll. It tills nice and penetrates for some reason faster than the Ford. Both are forward directional.
Not sure if there is a price difference between the two directions
Just wondering from experience what you all think of these two types of directional tillers. I suppose are tillers either one or the other or does someone offer one that does both?
I guess they make tillers to fit the size tractor, so what I'm looking at is around the 23 HP range give or take 1-2HP perhaps.
Kubota says they own Land Pride. But the SRT 48: that the Massey dealer recommended as I think it was a 1/2 inch deeper depth, which I'm also interested in. Currently, I guess I never measured, but I only go deeper if I first spaded an area. My plot is about 60"x60".
It is probably one of those decision where I'll be happy whatever I get, but wanted to be as informed as possible.
thanks
thanks
