STX46 gas leak
   / STX46 gas leak #1
BGT
I've got gas....ummmm, well, the mower actually has gas coming from somewhere, and I can't figure out where.
I've already replaced the tank and fuel lines with new. Bottom of the carb is dry. Area around the inline fuel filter is dry. Visible fuel lines are dry.
Mower resides in the garage and there is no gas puddle on the concrete but when I start it up, it then makes a puddle, followed by drips as I exit the garage. It starts fine and runs fine.
Anywhere else I can check for this leak?
Thanks.
   / STX46 gas leak #2
Thanks.
Fuel pump, if it has a Kohler engine
   / STX46 gas leak
Patches, you are correct: Kohler 15hp. Didn't even know the thing had a fuel pump, but then, I'm not mechanically inclined in the least.
I googled the problem, and found another thing it could be is the float in the carb is sticking, allowing fuel to leak into the cylinder while it's sitting. Maybe that would explain the fuel being blown out of the muffler when I cranked it yesterday.
The solution to that problem was given as a carb rebuild kit, or simply turning the fuel flow off at the inline fuel filter when finished for the day, which is what I did.
I suppose the test will be if it still spits fuel out the muffler today, it must be the pump; otherwise, must be the float.
   / STX46 gas leak #4
My STX is gravity feed. The original float needle valve on mine had an elastomer (rubber) tip that went bad. The replacement was solid brass, and never sealed as well as the original.
I always shut off the fuel valve when the engine is not running.
   / STX46 gas leak
Must be that needle valve. After sitting overnight with the fuel shut off, I turned on the fuel and cranked her up yesterday - no signs of fuel mist or spill. Guess I'll have to start shutting mine off too. No need replacing it if it doesn't work much better.
Thanks again.
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
