STX38
   / STX38 #1
pemassa
stx 38
Why does the pully on top of rear drive keep stripping? Do I need to rebuild the rear axle?
   / STX38 #2
a worn pulley moving around will finally take it's toll on the input shaft. I have seen people take a new pulley and shim it down a bit to get a new place for pulley to bite shaft
   / STX38 #3
The STX38 is a John Deere riding mower with 38" mower deck. The one I had was manual transmission with 1-cyl engine. There is a TBN section for mowers and lawn tractors.
If the input shaft on the final drive is keyed and the key keeps shearing off, first look for a sloppy fit and remedy that. Does the shaft turn easily by hand?
   / STX38
I did change the pully once, and it sheared shortly after, I guess the rear drive might be hanging up. Does it need to be rebuilt? Thoughts? TBN?
   / STX38 #5
what is the model/serial number on your STX?
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
