STX 38 starter
   / STX 38 starter #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
The starter on my mower quit today (Kohler CV 13S). The dealer wants $172 plus tax for one!
Has anyone tried rebuilding one of these?
Any recommendations for a source of good used parts?
Thanks!
   / STX 38 starter
I've learned a lesson I'll bet a lot of people already know!
After a lot of fooling around with the dealer, it turns out a set of brushes are almost $55 and would take 2-3 days to get unless I wanted to pay freight!
I looked online and found complete starters with a warranty for $65 including freight.
Arrived next day and works perfectly.
Fortunately, I have another mower so I could waste time fooling around with this.
   / STX 38 starter #3
Are you sure that the starter is bad? If it does nothing when you turn the key it could be a wire problem or your PTO switch is in the on position. Either one could cause the starter to do nothing. I had a mouse chew a wire off right next to the starter (a small wire plugged into the bottom of the starter solinoid) and the started was dead. Spliced the wire and everything went back to normal. Another time when mowing I turned the mower off without disengaging the PTO switch. Same thing, no power to the starter, Shut the switch off and everything returned to normal.
   / STX 38 starter
It no longer had enough torque to spin the engine with 12V across it. When I took it apart one of the brush wires had burnt off. I tried to attach a new wire, but ended up destroying the brush.
Thanks anyway.
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
Massey Ferguson 9250 (A53472)
Massey Ferguson...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A51248)
UNUSED RAYTREE...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
