Stuttering hydralics
   / Stuttering hydralics #1
Cutterhead
Washington
Kubota L3400
I have a Kubota L3400 and the last few times I've used it I've noticed that as I raise the FEL it will go up smoothly a bit, then stutter as it goes up, then smoothly. It also seems like the steering is doing the same thing when I turn the wheels. Fluid level is fine. Doesn't matter the engine RPM. Cold or hot. Any suggestions?
Thanks!
   / Stuttering hydralics #3
Check for air in the system.
Inspect the suction hose and re-tighten all clamps.
I couldn't see any specific holes, but there was clearly a leak; the hose was covered with gunk. Looks like a relatively easy fix - but a bit shocking that a part like that would fail on my tractor with less than 175 hours - and it seems I'm clearly not alone on this one.
Thanks for the help!
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
CASE IH 2412 - 12R CORN HEAD (A51247)
CASE IH 2412 - 12R...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
2019 DODGE RAM 5500 SERVICE TRUCK (A51247)
2019 DODGE RAM...
2023 JOHN DEERE 7R210 LOT NUMBER 87 (A53084)
2023 JOHN DEERE...
