Stupid Shear Bolt
/ Stupid Shear Bolt #11
I noticed a new mower at the dealers with a plastic access plate in the plastic boot. Seems like a real good idea at least until it falls off and you lose it.
Chris
/ Stupid Shear Bolt
Usually it takes me more time to dig the tools and new bolt out of my tool box than it does changing the bolt. I seem to bust more bolts hitting high spots on the ground than anything else. I broke one bolt on a hidden fence post, and one on the log in the field. All others were on high spots. I am hoping that I will "scalp" them off after a few mowings and not have to worry about as many bolts.
/ Stupid Shear Bolt
<font color=blue>I would take the shield off if it is in the way of replacing shear bolts. </font color=blue>
There has a metal shield that bolted on to the gear box on mine. After replacing the first shear bolt, it now sets in the corner of my shed until I use it in a future welding project.
/ Stupid Shear Bolt #14
I have a Rhino SE-6 and the first time I sheared a bolt I had the same problem. After I replaced the shear pin I noticed that there was a grease fitting there and I greased the fitting. I've sheared two bolts since then and both were clean. The only thing I can figure is that the ungreased fitting did not allow the shaft to come around fast enough to shear the pin completely off.
/ Stupid Shear Bolt
Yeah, I noticed that grease fitting to, I figured it was there to prevent wear on the gearbox shaft when you sheared a bolt. I never thought it might help the bolt shear better. I had sheared a few before and never had that happen until the last one.
FUEL CELL (A58214)
FUEL CELL (A58214)
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Infiniti QX60 SUV (A59231)
2017 Infiniti QX60...
