Stupid (read: unexpected) ways to hurt yourself with your tractor.
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #21
A silly mistake my friend Giles made several years ago...
Giles has a sheep farm in the centre of a small village in the Forest of Dean, Gloucestershire, England. Like many of the farms in the Forest, his machinery is old and not very well maintained. As a result his Fordson Major (fitted with a second hand 6-cylinder Leyland Engine) wouldn't start one morning - despite having been left on a slope the night before, the gradient wasn't enough to get rolling. Giles tried all his usual tricks, and ended up resorting to using "easystart".
He decided the best thing to do would be to spray a little into the air intake, while cranking the engine at the same time - but this was not possible to do from the seat. So stood next to the tractor he placed one hand onto the clutch pedal (to activate the safety switch), quickly sprayed some easystart into the air intake and then with the same hand immedately reached for the key. It worked a treat and the engine fired up.
Unfortunately Giles had forgotten to put the tractor into neutral after trying to bump start it, so as soon as he let go of the clutch pedal the tractor took off in top gear, running over his own foot and then crashing into the barn! Giles spent the next 4 weeks limping around the farm with his foot in plaster, which meant he couldn't even get onto his tractor to remove it from the ban wall - much to the amusement of everyone in the village! :laughing:
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #22
+ another shin on the hitches!
People steal trailer hitches where you live?!?
Yep here too., If NOT LOCKED UP they will steal anything. Had a drop taken from my
blazer parked at a friends farm parked 25ft from the shop held with a bolt and nut.
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #24
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #25
I know what you mean about the ROPS, if you're not careful you will fine yourself watching the exhaust muffler in front of you for clearance, and forget about how high the ROPES are behind you. I've started lowering mine if I'm not cutting slopes or road banks. FYI people "including me" sometimes forget to watch the ground wire when cutting around power poles! LoL
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #26
Will anyone admit to dropping a 3pth implement on their foot using the handy rear 3pth lever? I haven't but I did almost get myself hitching up my rear blade. I was trying to line up the toplink using the bottom lift arms and I bumped the lever up way too much and the blade almost swung in to chop me off at the ankles...
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #27
No, but I will admit to tripping over the end of my landscape rake in the dark. I forgot I had it attached instead of the mower and it sticks out a couple feet wider than my mower deck. :eek:
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #28
One evening I went to put up something in the rafters of the barn, and stepped up on an old wooden folding chair.. it exploded in a bunch of pieces and I fell backward on my rotary cutter. The King Kutter rotary cutter has a lot of vertical upright pieces and I landed right on them.. I poked a couple of holes in myself, but nothing serious. Could have busted my brains out on the transmission, but it didn't happen. I was pretty sore for a while though.
James K0UA
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #29
No, but has crossed my mind a couple of times, and I have looked down, and saw my ballast barrel just a couple of inches from my foot.. At 750 lbs I think it would hurt. I made a mental to note to check the clearance each time:) and to use this new feature carefully.
James K0UA
   / Stupid (read: unexpected) ways to hurt yourself with your tractor. #30
Does hitting your head on the feather board and breaking it off on a sickle mower count.
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Towable arrow board (A55973)
Towable arrow...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
