Ballast Stupid question about ballast box
   / Stupid question about ballast box #1
Mrb94
Doylestown, OH
Bobcat CT225, Craftsman DGT6000
I have a question about using my ballast box:
Should it be used in the full up position, or keep it low to the ground?
Sorry for asking such a stupid question, but this is my first "real" tractor and I have no idea what the right answer is.:eek:
   / Stupid question about ballast box #2
Since you will be using the ballast with a loader there is no reason to keep it low to the ground, I raise mine up, at least high enough to clear any ground cover.
   / Stupid question about ballast box #3
I also keep the box high..easier to keep eye on also from rubing the ground.
   / Stupid question about ballast box #4
I keep mine as low as possible, not low enough to drag. but I keep it low to keep the center of gravity lower. should be more stable or atleast it worked that way in my head
PG
   / Stupid question about ballast box #5
depends, is your ground perfectly flat?
Keeping your center of gravity as low as possible on a tractor is a good idea. I keep ballast as low as possible - ie right over the height of things like curbs or rocks I might back into. This is much more important on hills obviously
SHOPMADE MANIFOLD TRAILER (A58216)
SHOPMADE MANIFOLD...
35176 (A55758)
35176 (A55758)
Lincoln Electric Ranger 10000 AC/DC Welder Generator (A56857)
Lincoln Electric...
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
HEAVY DUTY TRANSMISSION JACK (A58214)
HEAVY DUTY...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
