Stupid Chainsaw tricks..
   / Stupid Chainsaw tricks.. #11
Robert , you and I have the same college.Outdoor nationals.Its a treat to be able to discuss things with factory mechnics. Al
   / Stupid Chainsaw tricks.. #12
I'm 100% with robertN on this one, for MIX ratio, mix per the OILS manufactures specifications. not as much the equipments manufactures spec.
running 2 cyc with out oil will cause it to loose the lubercation it needs internally, from piston & rings to seals & bearings. that much cutting probably shortened it;'s life, like others said now adding MORE oil won't help at all, damage is done, only make sure to not doing that same thing . use seperate cans, I use 2 different 1 gallon gas cans for my chainsaws/weedeaters. both use same oil (poulan synthetic stuff) even though the weedeater is a homelite. I buyt the MIX in quart squeese botles, and put the oil in prior to the gas, fill one can only when the other is nearing empty, this way I always have a full gallon of mix. nearing end of sawing season entering weedeater season. so I always have a good gallon of gas. they poulan stuff also has gas extender type additive to prevent it from going bad as quick.
also this means I nnever fill these 1 gallon cans up with cheap gas, I put in mid grade gas not the 86/87 but the 89/90 stuff. I've run the tar out of all of these machines cocmpaired to a normal home owner/farmer so far they fire right up easy as pie. I wore out 3 bars on one saw and have 8 or so chains in rotation used ti for cutting Rail road ties and soft maple. it cuts it all, but trust me when I say I tie is something that is HARD on em. even worse was the SPIKE I hit in one /forums/images/graemlins/crazy.gif
mark M
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
Pickup Truck (A59230)
Forklift (A59228)
Forklift (A59228)
