Stump was a little too big for the Kioti
   / Stump was a little too big for the Kioti #32
Soulasphil, question about your loader, is the lift cylinder 'under' the tractor ?
   / Stump was a little too big for the Kioti #33
Yes, the single cylinder is under the tractor. It's quite big and pushes forward a very heavy metal bar to which the bottom of the loader arms are connected. When you remove the loader, the cylinder remains underneath the tractor, so no hydraulic problems.
Wow....that's a deal Joel. Do you run your well pump off of it, or do you have municipalized water? I need something that will provide a surge for the 1hp pump. Unfortunately, we do not have Pep Boys here....but we do have a TSC.
Yes, I run my well pump, the only thing I don't run is my kitchen oven and stove top, that thing draws some serious amps.
The generator does stumble a bit when the pump kicks in, I think I'm 3/4HP, deep well, 400+ feet deep.
My neighbor also has a well, as noted in previous note, he ran about 8 days straight, shut down to change oil every 25 hours started back up and kept right on going, no worse for wear, no smoke, nothing, still running great.
I am very pleased, particularly considering I dont run it very often, seemed silly to spend a lot of money.
Joel
   / Stump was a little too big for the Kioti #36
Joel
Hmmmm..... So power-outs are barbeque time!
Most pumps are 3/4hp, but I try to overdo everything. I'm 305' deep at 28 GPM. I need about 6500 watts surge to start my pump. My stove is duel-fuel, but my fridge is a 48" monster.
I hear ya' about spending money, but I've used the generator about 6 times last year - 4x in the winter months. I was thinking about a permanent. propane fuel automatic transfer unit, but that's big tomatoes.... I think I could get by with a 7K on a cart.
I would think 7k would be more than enough. I've run my well pump with TV, Lights, Furnace going. Not had a problem, but 7K would give you a little more buffer.
I'm very happy I've got mine.
I just bought an hour meter to install on it so I can keep better track of oil changes.
Joel
2016 Ford F-150 Pickup Truck (A55973)
2016 Ford F-150...
2017 ford explorer (A56859)
2017 ford explorer...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 Deere 550K (A53317)
2019 Deere 550K...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
