stump speech
   / stump speech
You're still gonna get oil on your hands when you plug the hoses in, so you may as well save your money, unless you have another reason to get a diverter, like for your grapple. When you've got the thing hooked up you're not gonna be scooping anything..
   / stump speech #142
   / stump speech #143
Muhahahahahaha! :punch:
This KICKS BUTT!
I LOVE this thread! Oh man...where have I been! :banghead:
I might have to expound on this someday! A lil CAD and some Q's,
maybe some luck on a nice sized cylinder and chain and and and. Gawd how FUN!
yep, as someone said, imovable objects and instoppable forces are FUN!
I am already kakniving! How about adding a block and tackle to this w/ cable! HA!
Probably save on cylinder costs ehh? Hmmmm...well, gotta buy the Block and Tackle
but hey! HA! Love it!
   / stump speech #144
I was thinking about building a hydraulic winch for my loader so I can keep the hoe attached to loosen up the stump first. I have quick attach so it would be handy. Of course it would be designed to dig in and have a tilt capability.
   / stump speech #145
Jake was really thinking outside the box on this one.
So cool...Gawd I love this stuff. Just now I was looking
at cylinders when I saw this reply come in . Very Cool it is.
(Except one gent here suggested Grade 100 Square link chain.)
Well, I went looking for that and I think he meant to say "grade 120"
chian, and it is prohibitively expensive. McMaster was at $28.xx
per foot, i found it elsewhere for 18, still WAY expensive.
Cables and chokers perhaps?
   / stump speech #146
Cable is lighter and has more than enough strength. That's why I like the hydraulic motor because I can just set a relief pressure and it will be safe.
   / stump speech #147
DO ya suppose these cylinders are up to the task?
I just found 4 of them CHEAP.
Ummm....there only 24" stroke...I see jake used, I think anyways, looks like a 36" stroke.
Yea that would be better huh...
Type Double Acting Tie Rod
Bore Dia. (In.) 5
Stroke (In.) 24
Rod Dia. (In.) 2
Retract (In.) 36-1/4
Port Size (SAE) 7/8-14
Max. Pressure (PSI) 3000
Piston Material Cast Iron
Piston Rod Polished Chrome
Ring Material Cast Iron
Tubes Precision Honed
Rod Seal Urethane U-Cup
Material Steel
Tie Rods Steel
Piston Seal Crown
Finish Painted
Includes Pins and Retainers
Pin Dia. 1-1/4"
   / stump speech #148
You might break a chain with 5" bore. That's about 40000 lbs!
   / stump speech #150
Well, 32k out of 45k ultimate strength won't break it assuming you don't have any nicks in your chain and your hooks are up to the task. It's still cutting it close unless you use two chains in my opinion.
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
Freeland 100 gal Water Trough (A50515)
Freeland 100 gal...
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
15 FT Trailer (A50322)
UNUSED MOWER KING SSFFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
