Stump plane
   / Stump plane #11
Almost all of the videos I have seen were made by the company that is marketing the machine. As one might expect, rocks are never identified as a problem. I would speculate that the bits are robust enough that a slip clutch or shear pin in the pto shaft or by-pass in an hydraulically driven grinder would trip before the bit were damaged. One of the US manufacturers, I think it is Fecon, states that the bits are easily repaired or replaced in the field, Take that for what it is worth.
   / Stump plane #12
I wondered about rocks too. We have lots of them. I have a water line that goes under a rock I couldn't get out with a trencher. But then I wonder how those stump grinders with high-speed wheels do in rocks.
   / Stump plane #13
Short answer: About as well as rotary lawnmowers.
Longer story: My fascination with vertical axis stump grinders is a pipe dream. Prices start around $18K and require a high flow skid steer, 100+ HP tractor, or a several ton excavator, none of which I have. I purchased a 24" horizontal axis "buzz-saw" stump grinder for around $5K.
I live on a hill of glacial till, everything from clay to boulders the size of small cars that was bulldozed by the glaciers. Before I grind a stump, I excavate a bit around it to remove easily handled rocks and identify the location of boulders not easily moved. I will still encounter rocks and, while I have not (yet) broken a carbide tooth, I have sent a golf-ball-sized "pebble" flying 20' despite the mud-flap-like deflector..
   / Stump plane #14
That's about what I'd expect. :)
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
Eagle Weathervane (A55853)
Eagle Weathervane...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
