Stump grinding / removal
   / Stump grinding / removal #1
Bill Guenthner
Platinum Member
Kentucky
Kubota B3300SU
I have a large wooded tract for recreation and hunting. I've got an acre or so that we clear cut several years ago and now it has a good stand of grass on it but the stumps are still there, about 30 stumps anywhere from 6 inches to 30 inches but mostly under 20 inches diameter. I want to get them down to ground level so I can run the bush hog over them or drive the truck across the field. I don't necessarily care about getting them below ground I just don't want to have to mow around them or to hit one in high grass. Obviously I don't want to pay $100 or $200 apiece to get rid of them the way you would with one in your front lawn. In my experience trying to cut a stump to ground level with a chainsaw will just get you a ruined chainsaw. Any suggestions?
   / Stump grinding / removal #2
I would hire someone with a huge dozer and rock rake. In a matter of a couple hours they would be history and neatly stacked in a desired location. I have hired the small 60-80 hp machines in the past. They spend time, cost money, and get little done in the results catagory. Good luck.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2015 John Deere 7700A Precision Cut 100in Reel Commercial Mower (A52377)
2015 John Deere...
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A54757)
UNUSED WOLVERINE...
RING 2 STARTS HERE @ 9:15 AM (A54756)
RING 2 STARTS HERE...
