stump grinder vs backhoe
/ stump grinder vs backhoe #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
my neighbor has an older vermeer 206 stump grinder (only 34 hours!) that he is willing to let me use but having never used one i wonder if it would just better to use my backhoe to remove the stumps. what do you think, stump grinder or backhoe?
/ stump grinder vs backhoe #2
Stump grinder, no filling in holes.The great thing is you don't have to buy one....:cool2:
/ stump grinder vs backhoe #3
Try it out. If it works give the man some money towards replacing the cutters for using it. Alot better than tearing out roots and disposal. Good luck.
/ stump grinder vs backhoe #4
Keep in mind that if you grind in down, there will always be something in the ground to decay. You will continually have to fill in that area in the future
Sent from my iPad using TractorByNet
/ stump grinder vs backhoe #6
i would use the grinder it will take longer but theres no stump to burn
/ stump grinder vs backhoe #7
Use your backhoe to clear away any rocks then grind them - by far a better solution. The roots will decompose very slowly - I have done both and grinding is the best way and less mess and root cleanup.
Just get down below the ground enough 6-8" then topdress with dirt and seed. The 206 is not a big grinder so it will take time for the big stumps.
/ stump grinder vs backhoe #8
It depends if the area will be used for a concrete foundation. Dig them up if that is the case.
hugs, Brandi
Looks like I should take him up on the offer..these are just random alder stumps from trees I have cut down in various places. The motivation is to get rid of them so I no longer have to mow/trim around them.. most of them are cut off a foot or so above ground. Should I chainsaw cut them closer to the ground before grinding? Would think this would minimize the time on the grinder if I did so..
2024 HD MFG GOOSENECK TRAILER (A59914)
2024 HD MFG...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2004 GMC Sierra 2500 (A66408)
2004 GMC Sierra...
100 gal L Double Fuel Tank (A66408)
100 gal L Double...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
2023 General XP 1000 Sport (A62679)
2023 General XP...
