Stump Grinder ???'s
   / Stump Grinder ???'s #1
Scotty370
Platinum Member
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
Stump Grinder Questions!
I want to build a 3 Point hitch Stump Grinder Attachment patterned after several after market units out there for my John Deere 4200. (26hp 3cyl Diesel w/ Backhoe/Bucket). Two immediate questions: What is the cutter wheel rotation suppose to be? I say lower teeth should be moving toward the tractor. Thus if your standing on the right side of the machine it would turn counter clockwise! The PTO turns counterclockwise (Doesn't it?) thus a right angled gearbox mounted on the left hand side would cause it to turn as described! This would cause the tractor to be pulled toward the stump when cutting. I think that's safer than having it try to launch the tractor forward. Also, Wouldn't it relieve 'side pressure' bearing wear if I were to build it with a shaft mounted cutter wheel supported on both ends with pillow blocks? I would leave a splined end facing the gearbox that I could hook up with a Lovejoy type connector. (IE two internally splined metal hubs with a rubber insert. Also I need parts sources for the wheel if I don't 'tooth up' a piece of 1/2" plate. I'm thinking a 24" wheel! Any help appreciated! ~Scotty
   / Stump Grinder ???'s #2
   / Stump Grinder ???'s #3
I should also add that you will not get the feeling of the tractor being pulled toward the stump.
When you put the unit down there is a C channel with grooves cut out to make teeth. The unit doesn't move to much when that is down.
Also you will not be able to chip to much at a time your [and mine] machine will bog down. you can get a couple of inches but after that it starts to bog down. especially on a fresh cut stump.
My teeth have to come from the dealer which isn't to bad a price at $18 a piece until you figure i need 36 ouch.
I am not sure where you are located but i may be selling my PTO gear box off of my stump grinder.
Shane
   / Stump Grinder ???'s #5
Hi..
Just a word of warning,,,
PTO grinders are very hard on the pto unit..
My experience has been that the grinders are
stronger than the pto units, will do damage even
with a slip-clutch..
Bob
   / Stump Grinder ???'s #6
Hi..
Bob
I guess that would make brush hogs and PTO wood chippers very hard on the pto unit?
Wedge
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
