Stump grinder losing power
   / Stump grinder losing power #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
Hi all
My stump grinder lives a pretty harsh life. Yesterday's heat may have lead to a problem.
Losing power, rpms are about right but the tool stalls even when engaging in light work.
Is there a rebuild process for the internals?
Thanks for any help.
   / Stump grinder losing power #2
Sorry to hear it.
Can I ask a question; Have you double checked that it isn't something wrong with your relief valve?
Similar RPMs, but stalling under light work sounds more like a relief valve than a motor. Usually a motor will lose RPMs as well as stalling easily.
One that had loosened would show the same symptoms, and ditto for one that had a bit of debris caught under the relief seal. Absent JJ's handy dandy pressure gauge on your PTO, I would be inclined to chat with Terry about how best to disassemble and assemble the relief valve to check for a blown seal or debris.
All the best,
Peter
Thanks, Peter. I'll be able to get a gague on it this weekend. Other attachments are functioning well which key me suspicious of the grinder.
I'll check with Terry next week.
Happy 4th!
   / Stump grinder losing power #4
Is the head belt driven? Could be slipping at the pump/motor connection...
Thx, direct drive.
   / Stump grinder losing power #6
Direct drive - is it a splined coupler or? Can any slippage take place between the motor and cutter? Sheared key? Is any fluid noise coming from the motor that may change under load? Does the motor get hot quick?
Not hearing any unusual noise. Impossible to tell what's hot fast... It's 95 degrees... But I switched to the trencher and had the expected power, same with the power rake...
No slippage. Just really anemic.
Any body know the internals of the roller stator hydraulic motor? Could a seal have been pushed out?
   / Stump grinder losing power #8
The fact other implements work does focus it on the grinder. Yes, I agree, it is probably a blown seal. Yes, it can be rebuilt, but I don’t know if PT sells a kit. You are going to need the seal kit and a really clean area to do it in. Tolerances are pretty tight.
Stump grinding has to be hard on the motors. When you do get it rebuilt or a new motor break it in slowly to keep the peak pressures low until all the seals have a chance to seat properly.
All the best,
Peter
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
3" X 3" WP-80 WATER PUMP (A52708)
3" X 3" WP-80...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
White Metal Roof Panels (A55758)
White Metal Roof...
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
