Stump cutter
/ Stump cutter #1
mytoyz
east texas
kubota l3301
Am looking for any ideas on making or purchasing an implement to cut stumps at ground level. I have a Kubota L3301 so I'm hp restricted. I will be using it on pine trees up to about 24''. Turbo Saw may work. Thought about transforming old bush hog w/buzz saw blade. Would prefer to buy ready made. Thanks for any help.
/ Stump cutter #2
I recommend renting a stump grinder. You can rent a self contained unit with all hydraulic controls for under $400 a day.
/ Stump cutter #3
agreed! you will spend way more than $400 to make something hydraulically powered to do what you are wanting.
/ Stump cutter
Thanks for the replies. I wish someone would make the Turbo Saw in a slightly smaller version for the smaller tractors. But for now it looks like I'll be renting a stump grinder or possibly looking for a used one. Thanks again.
/ Stump cutter #5
Don't sound so depressed, I never used a stump grinder, but it sure looks like a load of fun!
/ Stump cutter #6
dynamite or nitrogen fertilizer and blasting cap. Quick and simple.
/ Stump cutter
So true Oldnslo. They won't let us have the fun stuff like c4 or primer cord. That would do the trick.
/ Stump cutter #8
How many stumps do you have to cut?
Are your stumps in rocky soil?
We do have a stump saw and are in east texas.
Would be a shame if you were my neighbor.
Of course east texas may be larger than some states.
Send me a private message if you like.
/ Stump cutter #9
I purchased a turbosaw about 2 years ago and have used it on a 30 HP pto John Deere 3038e. It is a load for the tractor and strains the tractor getting the saw up to speed. It cuts trees up to telephone pole size easily. I do not have rear hydro so I cannot use the grapple. If a larger tree leans towards the tractor it will bind the blade and stall the tractor. I have cut about 500+ eastern red cedar. Sizes from 1/2" to about 20" stumps. On level ground you can cut the tree at or slightly below ground level. I have not rotated the teeth yet, but about 1/2 of them are chipped by hitting I believe metal in fence lines. (a couple of electric fence posts, imbedded barb wire and woven wire, and a couple pieces of scrap metal.) I get hit by wood chips when cutting trees, and the ROP has saved me from a couple of trees that fell on the tractor. I found it safer to cut larger trees with a chainsaw at 1-2' above ground and cut the stump with the turbo saw.
/ Stump cutter
Actually right now I have removed standing stumps w/chainsaw & ax. I know I will have many trees to cut in the future and do not want to go the chainsaw/ax route anymore. I have good ole red clay w/few rocks. I am south of Henderson. My tractor has only 28hp at the pto.
/ Stump cutter
I had also planned to cut my pine trees w/chainsaw then cut the stumps w/tractor mounted saw. Would not dare try to push a tree over with a tractor mounted saw attachment. (no room to run on a tractor). Like I stated in another reply maybe someone will make a turbo saw that will work for a smaller compact tractor (mine is 28hp pto). Even if it takes several swipes at the stump it is better than digging one up or using a chainsaw & ax.
/ Stump cutter #12
I don't push trees....nor would I cut them with a tractor mounted saw. Danger written all over that practice.
I have ground out over 1800 stumps on my land.....and have lost track of the number.....but I suppose it's over 2000 now. I first used rental grinders for about 600 stumps. Later bought a Woods grinder and use that now. I have a few miles of trails and great food plots and shooting lanes as a result. Pine stumps (cut close to the ground) only take a few minutes if everything goes right. No stumps to bury or dig out or burn, etc.
I hooked the two hydraulic cylinders to my loaders joystick to sweep and alter the elevation of the cutter head. Works slick.
