Stuff you find while mowing tall vegetation
   / Stuff you find while mowing tall vegetation #11
box spring, water shutoffs, elevated manhole covers, steel pallet straps, wire fence, t posts, barbed wire, tons of concrete and a cable pedestal. I got stuck cutting hundreds new residential development sites over quite a few years.
   / Stuff you find while mowing tall vegetation #12
A pile of nylon twine from square bales. Wrapped around my flail mower with a vengeance. sat there with my pocket knife for 45 minutes cutting 6-12 inch pieces off. :cautious:
I just pulled a piece of net wrap from around my rear axle.
Took out the rear axle seal.
Special place in hell for those who leave twine & net wrap in fields.
   / Stuff you find while mowing tall vegetation #13
Gophers and rabbits, but they don't make any noise, at least none I can hear with my noise cancelling FM radio headset turned up pretty high.
Did hit a plastic gauge wheel I had lost off the mower deck on the BX a couple of years ago. I did hear that.
   / Stuff you find while mowing tall vegetation #15
   / Stuff you find while mowing tall vegetation #16
Over the years I’ve found car batteries, tires, an automatic transmission, a manual transmission, car doors from an oldsmobile, brake drums, antique cow stanchions, a pile of asbestos siding shingles, barbed wire, cinder blocks, a pile of old red clay drain tiles, fence wire, a 14’ green colored wooden boat, jimmy hoffa, a model T frame with the crossbuck springs and axles sunk in the dirt, a coal pile and a few other things.
   / Stuff you find while mowing tall vegetation #17
A ratchet strap will make a bit of noise if it hangs onto the blade.
That reminds me that I blew the left rear wheel off of my front mounted brush cutter when I hit a large ratchet strap ratchet in the grass along the highway many years ago. BOOM!
   / Stuff you find while mowing tall vegetation #18
   / Stuff you find while mowing tall vegetation #19
   / Stuff you find while mowing tall vegetation #20
Doesn't happen much anymore, but older tube TV sets.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
10 X6 MANIFOLD (A58216)
10 X6 MANIFOLD...
TRUCK TOOL BOX (A58374)
TRUCK TOOL BOX...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Kubota SVL75-3 (A57148)
Kubota SVL75-3...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
