Study: Effects Of Ethanol On Small Gasoline Engines
   / Study: Effects Of Ethanol On Small Gasoline Engines #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
The Oak Ridge National Laboratory (ORNL) has completed a study on the effects of various ethanol/gasoline blends on legacy vehicles and small non-road engines. It's rather lengthy. I have not read the whole thing yet, but the effects of running ethanol "enhanced" gasoline in air cooled power equipment include two noteworthy issues:
1. The engines run hotter. For those of us with equipment that already is marginal in the engine cooling department, this is not good news.
2. Some engines idle faster, sometimes to the point that centrifugal clutches engage at idle. Chainsaw owners take note.
3. Fuel consumption will be higher.
You can download a copy of the PDF version here.
   / Study: Effects Of Ethanol On Small Gasoline Engines #2
I had carb problems with 10% ethanol 87 grade here about 3 years ago. My lawn tractor's mixture screw had to be adjusted every 1-1/2 hour of run time. I mentioned this to 2 local small engine shops. They said, "your running 87 aren't you".
I have been running 93 octane here that contains no ethanol on every small engine I have. I really think 87 octane is not what it use to be like 20 years ago (Period)
Dan
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
