Ok Nelson, I'll give it a shot.
After failing to unstick the tractor with the FEL and 4wd truck, I tied a chain through the rear left tire and wheel. I hooked the end of the chain onto itself on the front of the tire, near the ground, and the "knot" was as tight as I could get it. Then, I tied additional chains to a tree in
front of the tractor approximately 40 ft away. After the chains were in a straight line and connected, I drove forward in A-1 until the rear tire began to drive up onto the chain. However, because the rear left tire was at a slight angle to the tree, the tractor was pulled more sideways than forward. This is when the front right tire was pulled off the rim.
Realizing that wouldn't work, and after much swearing, I was able to unhook the bush hog from the tractor so that we could attempt to pull backwards to a different tree that would give me a straight line to pull from. Then, we pulled the bush hog away from the tractor using chains, cable, and a 4wd truck. That worked really well.
Then, I unhooked the chains from the previous tree and tied them to a tree about 50-60 feet away that was
behind the tractor. Also, this time I used the rear right tire and it was fairly "square" to the tree.
I believe this was the major factor because I was able to keep the chain centered onto the tire and it pulled itself in a straight line. I started to drive in reverse in A-1, and as the tire began to climb onto the chain, I lowered the FEL and placed the flat bottom of the bucket to the ground as far as it would go to help get the front right tire out of the hole and to allow the front end to "slide" better. I had to adjust the chain a time or two as I drove backwards, but this worked like a charm!! It crawled right out of the hole! I had my old man helping me. It could be done with one man, but two certainly made it easier.
I hope this makes sense....
